Question about Kenmore 96212 / 96214 / 96219 Electric Kitchen Range
Kenmore range 655
We had a power outage a couple of nights ago and the key pad stopped working along with the oven. I discovered the SAB code and have attempted to deactivate it but now I get a code that reads "eo sab" and no response from the key pad. Any assistance is greatly appreciated!
  • Anonymous Mar 16, 2014
    I went to change time on range and was holding the clock button down and "Sab" came on screen
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
It is what is called sabath mode. it locks out the controls and lights ect. check your manual and it will explain how to deactivate the sabath mode for that particular range. good luck.
Posted on Sep 27, 2007
SOURCE:
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum
forum.appliancepartspros.com/oven.../2348-maytag-oven-weird-error-code-5ab.html Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ...
https://www.shopyourway.com/questions/1098960 Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from www.shopyourway.com
Maytag Oven SAb error code - YouTube
? 0:54
https://www.youtube.com/watch?v=XUP1BOzqPUo Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
Kenmore electric range model 970 6362 SAB code.How do i reset this so the oven works again?
Hello. Try pressing and holding the "clock" button until the "SAB" starts blinking. It will then clear and the normal clock display will be showing--your oven is in "Sabbath mode" presently!
Sep 10, 2015 | Kenmore Kitchen Ranges
Frigidaire gas range model ES330 error code SAb
This is SB mode, show room mode. To deactivate showroom mode, remove power and reapply. Press Cancel to bypass programming clock. Within 60 seconds of reapplying power, press Oven Light key and top oven Timer key simultaneously.
Aug 05, 2012 | Kitchen Ranges
I AM GETTING A ERROR CODE ON MY STOVE SAB OR SA6 HOWEVER NONE OF THE BUTTONS WORK
This is the Sabbath feature on my Kenmore Elite Electric Slide in Range. My oven manual says to press both the (timed oven) "cook time" button and the "delay start" button at the same time for approx. 3 seconds and this should shut down the feature. I had the same problem, tried the above and it worked.
Mar 06, 2011 | Kenmore 46564 / 46565 / 465 / 6646569...
I have a Kenmore double oven model #911.41185992 and it is reading a code of "fo". There are times that it beeps when trying to set the temp in the oven. If I turn off the power from the electrical panel...
The "F0" fault code is indicating a shorted OFF key pad. A technician would determine if the problem is the Key panel or the Control board by disconnecting the ribbon connector and measuring the flat cable pins 13-14. It should be open and should measure between 100-150 ohms while pressing OFF key.
He would disconnect power to range before testing the key panel.
I recommend calling a service technician to diagnose and repair your range
Mar 05, 2018 | Kenmore Ovens
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
241 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
