Question about JVC AV-32D305 32" TV
Power button it clicks on and off and will not stop, can i disconnect the switch and still have the remote working? if so, how do i disconnect it?
  • 398 Answers
No, you cannot disconnect the power switch. A defective power switch will not make the set turn on and off by itself, because the power relay is actually controlled by the microprocessor. The microprocessor in your set is trying to start the set but immediately detects a fault somewhere and shuts the set back off. This can be a difficult problem to solve and the set should be serviced by a qualified tech.
Posted on Aug 18, 2007
SOURCE:
My harbor breeze ceiling wont turn on.
  • Disconnect power at the source, not at the fan
  • Remove battery from remote. Press all buttons, then reinstall battery
  • Restore power. Using ONLY the remote, test operation
  • If the fan still does not work, disconnect power again and try every known combination of remote buttons and switch settings until the fan works or you give up in frustration.
Mar 13, 2017 | Dryers
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
Toshiba tv keeps on changing inputs at irreguar times on its own and the every button on the remote changes the input. have tried removing batteries from remote but problem continues
There is a known problem with Toshiba Tvs that options change with out any input of buttons or remote. the tv switch panel needs replacement. This is situated behind where the buttons are on your tv usually bottom right. there is a work round if you dont want the expense of part replacement. you can disconnect these buttons and only use the remote. This requires taking off the back (ensure tv is disconnected from power as there is high voltage in the tv) once the back is removed and tv is laying on its front you will see bottom left where the buttons now are, a couple of cables one will have seveal wires and one will only have a couple of wires take the smaller one off this will disconnect the buttons and stop the problem. once this is done you can only use the remote control to control the tv settings but the power on off button still works.
I hope this was useful.
Apr 05, 2011 | Toshiba REGZA 32AV615 32 in. LCD TV
When I plug in the red power wires, the module starts clicking
IT IS IN SAFE MODE AND NEEDS TO BE INITIALIZED BY DOING THE FOLLOWING:
If you have a 4 button remote, you must ground the black/blue hood pin wire (raise hood if hood switch is installed). Apply 12volts to blue/black brake wire (press and hold brake pedal if wire is installed). Press and hold any button on your remote until clicking and flashing stops. Unit will now respond to the remote. Remove ground from hood pin wire and voltage from brake wire. If you have a 2 button remote, hold brake and press any button on the remote until clicking and flashing stops.
Dec 27, 2010 | Remote Starter with Keyless Entry
Garage door open and closes by itself [email protected]
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
Feb 19, 2010 | Philips DVDR 3355 DVD Recorder
Sometimes the door opens with one push of the button
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
Loosen the staples with a small screwdriver and slide the wire about ?½ inch to move any areas of thin insulation away from the staples.
Or a remote in someone's purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button is defective..
Dec 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
RCA P52754AT rear projection tv won't turn on
Good way to test for bad buttons is go inside the back and there is a black multi-wire cable that is connected "front and center" of the center lens on top of the chassis....easy to get to from the back.
Disconnect it....
I've had touchy switches on this unit that cause the problems you're seeing....and who uses the switches? Your remote will still function, and with the buttons disconnected, the microprocessor won't get stuck servicing a false command....which by the way makes it IGNORE the remote when they go goofy on you..... Source(s): Over 24 years servicing TV sets......
Feb 11, 2008 | Televison & Video
JVC AV-32D305 32" TV Logo
32 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
