Question about Motorola Mobility RAZR V3c Cellular Phone
Phone handset not working unless on speaker phone
My mother in law is watching a business for her boss and had an issue with her phone not working unless she uses the handset on speakerphone. She does not have the bluetooth intstall and would like to know why after the ATT tech set the volume it worked for a little while and then went back to not being able to hear anything on the handset again. Already tried the Master Reset and that did not work. What can she do to be able to use the phone without using the speaker phone?
  • 34 Answers
Suggeestion if she realy need the cell back ot orinal you can relapce the whole complete speaker connetion cable that connect the buttom phone to the upper part speakers volume control and other vital lcd etec it just a calbe cost 5us
Posted on Oct 01, 2007
  • 29 Answers
Is this phone been dropped or wet? bring to a local service center to check if you have a physical damage on the phone.
Posted on Sep 30, 2007
When programing our incoming phone message this is a lot of static on the message which makes the message hard to hear. How do we correct this issue?
Cordless land line phone:
  • If it is possible to set the greeting from the base speaker phone, use that.
  • If the base does not have a VOX speaker, move the handset and the base away from anything that emits elelctro magnetic RF...like wifi access points, microwaves, etc and set the greeting.
Cell Phone:
  • Avoid using the handset to set the voice greeting unless your handset supports a visual voicemail service that captures the audio greeting first and then sends the audio file over the IP.
  • Call your cellphone# from a landline, hit # or * and your PIN, and access the greeting menu from there.
  • If your cellphone and carrier support Wifi calls, VoLTE or Packet switched voice service, set your handset up for hat feature. On an iPhone it looks like this:
Sep 04, 2015 | Lands Phones
Phone line repeatedly without reason goes to "in use" and will not go to a dial tone when receiver is picked up. the phone line does not do this when this att phone is not plugged into phone line
My first question would be, have you recently installed any after marked speakers, or radio into the car? You could have a grounded speaker wire, or connections not properly paired that could be causing the issues.
Jul 14, 2015 | Vtech AT&T CL82313 3 handset cordless...
Panasonic phone has duplicate handset numbers
Panasonic is famous for one handset not working. They like you to use their free repair, because then they can get the encryption code your phone system is using.
Local law enforcement frequently requires access to a suspect's stored phone numbers and/or conversations. So this makes it a bit easier for them to get that information. They just get the code from Panasonic.
I recommend that people just forget about the defective handset and store it somewhere.
Jan 20, 2014 | Panasonic KX TGA641 Cordless Phone
My idect twin solo second handset only works through speaker phone
My second set no display on Panasonic Mode KX-TGACM
Dec 21, 2013 | Lands Phones
I have a Uniden DECT1588 phone system, and the base phone, which is corded, has no dial tone unless I put it on speaker phone, which it works fine on speaker. The corded handset has no sound. I have...
Sorry to read about your problem, I hope this helps you out.
you just may have a bad handset cord. if you have another phone try changing the cords, or try a different handset
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Cell Phones
Speaker phone light continually blinks
The blinking light on the speaker button means the forward when busy is on. To cancel it- With the handset on-hook dial #12.
Then press your own station number. Then dial # again. The speaker button should stop flickering.
Note: If the SPK button continues to flicker, Forward all is activated. It is the same process as above but use #11 instead of #12
Feb 21, 2008 | Samsung Prostar 816 Phone
No dial tone unless on speaker
Suggest you check battery in non working handset is connected and charged. If this is ok, suggest you check this handset is registered with the base station, as out of the box they arent always set to the same channels
Jan 25, 2008 | Lands Phones
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Dec 28, 2007 | Avaya 700340193 Corded Phone
NEC DTU 16D-2 issue
hi,1.to adjust the ring tone volume. from your phone set,press speaker dial 601.press the arrow key up or down to adjust. 2. if your station is programmed as system admin phone,then you can press feature 80 feature.to toggle between day or night.do not press speaker button while doing this. 3.the headset port need to be program,or you can do without it,by purchasing the headset came with the adapter and connect thru the handset cord. the new model is DTH-16D. CAN email me if you need a new phone, sjohnnyh@yahoo.com
Sep 28, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
271 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
