I lost my manual for the TV codes for a Sanyo TV I was wondering if you had the codes to the TV for a Sanyo Model
I have a 15-2147. The codes from solution 1 didn't work for my remote, so I used the codes listed on Radio Shack's page for the 15-2142. The first code worked. Those codes are: 0154, 1907
Have a Sanyo DP19640 TV and used the following code with the Dish Network receiver. 590
Additional codes that I did not have to use are, 683,589,542,652 just in case the 590 does not work.
Just any code will not work, Do a search on your remote type. I have an "RCA Universal Remote" so I will search RCA Universal Remote codes . Then look at that & you will find your TV make, and the code will be there Good luck make sure it is the Sanyo TV .Cause there will also be codes for DVD players VCR's("Yes there still around!") Home theaters ,ECt., ECT, . Simple I save the page to Favorites after I find it
These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
2Turn on the component (the tv, dvd, etc).
3Hold the TV (or DVD) button and the on/off button at the same time until the on/ff button remains lit.
4Press the play button every five seconds until the component turns off.
Each time the Play button is pressed, the illuminated ON-OFF button
blinks ten times and a block of 10 codes is sent to your component.
This process continues until all the codes in the Code Lists have been
searched. If the component has not turned off after all codes have been
searched, the illuminated ON-OFF button blinks four times, turns off,
and the Auto Code Search Entry method is exited.5When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
6If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again.
This will isolate the correct code in the last block of codes sent.
Each time the REVERSE button is pressed, the illuminated ON-OFF button
blinks.If the REVERSE button is accidentally pressed after the component
responds, press and release the FORWARD button. Wait two seconds to see
if the component turns off again.7To save the new code, press and release the STOP button.
8The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
9If
component does not respond or has limited functionality, codes in a
different block list can be tried until you find the code that allows
the remote to control the majority of your component’s functions.
To continue past a block list of codes that provided minimal or no
control, turn component back on after being turned off from pushing
play and continue with step 4.
I bought a replacement remote for my Sanyo 26"... but the remote cannot access the MENU to adjust color ??? any thoughts ???
My sanyo tv is a earlier model and my girlfriend reset my remote when it was on video 2 and i cant get any remote to work for it now.
#5 worked on my Cox able remote for my Sanyo HDTV. Thank you!
I need the code to program my dish network remote control to a sanyo tv
Thanks for the 0154, worked for my Comcast remote! Not sure exactly which one, but has On Demand, DVR controls and PIP functions. Thanks again.
My old model big screen tv is being used with a comcast 3 in 1comcast remote and the tv is stuck on pip I can't remove it by using the remote what can I do the little pic is driving me crazi
I just had to answer because there are 15 answers hahaha
0154 worked on my older 32 inch thank you
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
How to put the numbers in it was hard finding all this stufff i need numbers for help
CABLE CODES ARE 4 DIGITS.
Password parent
Try one of these 017,021,039,056,057,058
SOURCE: Lost manual for 4 in 1Radio shack remote model 15-2114. Need Code
I have the same remote. The thing i found is the back of the remote says 15-2114 but Radio Shack website lists it as 150-2114 or 150-2114A. Hope this helps it worked for me last night, but I think the battery is low or something. Here is the link to all remotes by Radio Shack http://support.radioshack.com/support_video/15787.htm
tv codes for sanyo tv
How about Panasonic?
i have a 3 in one 15-2147 remote and i need the tv codes for a sanyo tv
I have a Sanyo model DS19500 tv. I need the codes so I can use my
Comcast remote.
need the code for a sanyo tv so i can use a universal remote
i lost my code manual for the sanyo tv how do i get the codes and how to set up
MY REMOTE FOR MY SANYO TV GOT BROKEN AND I BOUGHT A GE UNIVERSAL REMOTE AND PROGRAMED IT, BUT MY KIDS WERE PLAYING WITH IT AND THEY GOT THE CODE ALL OU OF WACK. NOW I HAVE MISPLACED MY OWNERS MANUAL TO THE REMOTE AND CAN T GET IT TO WORK.. COULD YOU PLEASE GIVE ME SOME TIPS SO I CAN MY REMOTE TO PROGRAM AGAIN.. THANKS, PATTY
my stupid brother
deprogramed my remote to a philips universal with a sanyo tv and i need the code
hellow i need sanyo code it a 14inche for a radio shack remote thank you
need code for sayno t v
i need the codes for a sanyo tv
neeed help
codes for remote sanyo (rmt-u110)
old small tv
MODEL DS31580 NEED CODE
I have universal remote, need to program a sanyo tv, what are the codes, no cable trying to watch dvds got sound no picture,cause I cant change the channel,.
ive put in counless codes and it none of them worked
xds
i lost the remote for my satalite and i need codes to get my tv remote workin for my satalite
i lost my manual for my remote and i need the code for sanyo tv
I need the cable code 4 digits for my sanyo model c25eg98b can some one help please
i need the comcast remote code for my sanyo tv. i tried 0514 and this didn't work. Does it not work for hdtv's?
What is the code for this model?
