Question about Dell 2 Button Mouse 6u226
Button Problems Hi. When i right click, the right click menu doesn't appear, but when i left click it does, but not on the net. I checked mouse control panel and everything was fine, the buttons weren't reversed and when i did that, it only made the problem worse (but i fixed that). What should i do?
    Problem Solver:
  • 51 Answers
Sounds like the button on the right might be sticking. I would replace the mouse.
Posted on Aug 17, 2007
SOURCE:
Won't print in black
  1. Open the Properties / Preferences window for the printer.
    For Windows 7
    • Click 'Start' from the bottom left of the Windows screen, and 'Devices and Printers .'
    • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/ Me/98 (if applicable)
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. De-Select the box for 'Grayscale Printing'.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Aug 27, 2012 | Canon PIXMA iP4300 InkJet Photo Printer
Sigmaplot 9 will not run with windows 7
1. Click the RIGHT mouse button on the icon for "SIGMAPLOT 9"
2. On the menu that appears click "PROPERTIES" with the left mouse button. This will give you a properties window.
3. Click on the "COMPATIBILITY" tab at the top right of the properties window with the left mouse button.
4. Tick the box "RUN THIS PROGRAM IN COMPATIBILITY MODE FOR:"
5. Click the drop down arrow and select the version of windows it ran in before or try "Windows XP Service Pack 3" and click APPLY.
If that doesn't solve the problem repeat steps 1 to 4 and this time select windows 2000. This should solve the problem.
Apr 20, 2012 | Systat SigmaPlot 9.0 (000053608314) for PC
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
HOw to replace the mouse left click and right click
The mouse click changes are based on OS used.
In windows OS ..Click Start button on your windows desktop. Select and click on Control Panel from the menu. Select and click Mouse from the control panel. From the Mouse Properties Window, select the Buttons tab. Select and check the Switch Primary and Secondary Buttons check box. Click the OK button.
Your mouse buttons should now be switched around, so now when you click your left mouse button, it will behave as a right-click, and clicking your right mouse button will behave as a left click.
Dec 01, 2010 | HP Compaq Presario C306US Notebook
I am trying to print on a custom sized paper (4.5"
  1. Open the printing preferences by accessing the Properties / Preferences dialog box.
    For Windows 7
    • Click / Select the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
    • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows 2000
  2. Click the 'Page Setup' tab.
  3. Click the down arrow to the right of the 'Page Size' drop-down menu to view the page size choices..
  4. Select the size that matches the paper you are using, and then click the 'OK' button at the bottom of the screen to complete the setting.
Oct 28, 2010 | Canon i9900 InkJet Photo Printer
I cannot get into my account. I emailed to get my password and it doesn't work. I do not know how to "paste and copy". Please help me.
You need to copy the password and paste it into the password box on the paypal website. To copy,
  • Click with your left mouse button just before the password.
  • Hold down the left mouse button and drag the mouse to the right until the password is highlighted.
  • Click the right mouse button and a menu will appear.
  • Click on "Copy"
The password is now copied into the computer memory.
To paste the password into the box on the paypal website;
  • Click the left button of your mouse in the password box.
  • Click "Paste"
You will now have pasted the password into the box.
Sep 03, 2010 | PayPal Accounts
I have outlook express and my delete icon has dissappered. so I cannot delete my e- mails
Do you see your menu's in Outlook Express? If so click with your right mouse button to the right of the menu that says Help. (right-click). Just click somewhere next to the word Help with the right mouse button and you SHOULD get tiny menu that pops up where one of the selections Toolbar.
Choose that Toolbar option with your left mouse button (left click the word Toolbar).
This will possibly allow you to see your missing DELETE button?
Let me know!
Thanks,
Kaj
Dec 18, 2008 | Computers & Internet
I have a Canon PIXMA iP2200. It has started printing so small I can barely read it. Also it goes off the right hand side of the page so misses the end of sentences. Can you help.
Scaled printing
  1. Access the printing preferences by opening the printer Properties/ Preferences.
    For Windows Vista
    For Windows 2000/Me/98
  2. Select the 'Page Setup' tab and under 'Printing Type', select 'Scaled Printing'.
Dec 12, 2008 | Office Equipment & Supplies
Poor photo copy when printing 4x6 glossy in cassette tray.
Set the Ink Intensity (Windows) The Intensity setting controls the amount of ink placed on the paper. The higher the intensity the darker (more ink) the printed image will be. If the Intensity setting is set too high, the printed page may become too wet and curl or streak. Follow the instructions below to adjust the ink intensity settings.
  1. Access the printing preferences by opening the printer Preferences / Properties.
    For Windows Vista
  2. On the Main tab, select 'Manual' for 'Color Adjustment', and then click 'Set'.
3.Use the slider bar to adjust the 'Intensity'.
Note: Move the slider bar right to darken the image, and move the slider bar left to lighten the image.
Click 'OK' to complete the setup.
I hope it helps!!!
Dec 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printing a banner via canon mx310
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
  2. Click the Page Setup tab.
and select printing banner and then apply ok then start printing
Oct 12, 2008 | Canon PIXMA MX310 All-In-One Printer
Dell 2 Button Mouse 6u226 Logo
97 people viewed this question
Clive
Clive
Alun Cox
