Question about Indesit W 123 Front Load Washer
Indesit W123s - Hates Us
On/Off door lock and the 'easy iron' and 'extra rinse' buttons all flash at the same time. Water constantly runs through and we cant change anything. Machine wont reset or drain and wont switch off. (has to be switched off at the wall). If machine is off and switched on at the wall it will spring to life, with the flashing lights and running water,as above. Machine is only 18mth old. Help...
  • pixiebell Jul 06, 2008
    i have the same problem, i did a wash this morning and then all of a sudden later today the lights started flashing and wont turn off unless i unplug at the mains!! also makes a sound like its emptying (althought here si nothing in the machine) can u help?
  • 30 Answers
First thing to do is to make sure the washing machine is not siphoning. sometimes if a washing machine is bringing in water its all so draining it ,known in the trade as siphoning. the drain hose must be higher than the tub?? Unplug your washing machine from the wall socket for a minute or two and plug it back in to reset its micro. to me it sounds like a main board fault. I think you might find that it still maybe under warranty. ring a Indesit service agent and get some advice.
Posted on Aug 18, 2007
Indesit wixl143 broken I try to start a wash it sounds like it should as I can hear water but it's not going into the drum and the door lock light is flashing rapidly along with the extra rinse light
Suggest you take the back off and home in on the water input filter. They are often gunged up with lime scale. Do pull the plug on it before you attack it with a wrench etc.
Jul 02, 2016 | Indesit Washing Machines
I have got Indesit WIXL 123 washing machine. Until yesterday, it was working fine. But today, when I started it, just after taking water and 5 initial spins, its Door Lock LED and 4th Function Button...
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
Oct 26, 2009 | Indesit W 123 Front Load Washer
Indesit 1000 cycle starts but then lights flash
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
May 21, 2008 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
478 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
