Question about Sony KP-53S65 53" Rear Projection Television
Convergence Well... not sure of the model number right now... but, the picture is there... mostly clear, but not using the entire screen. It looks like it's somewhat "peeled up" from the bottom right-hand corner... and appears to be a slight off-set of the colors on the right and left hand sides. I've been to the "convergence" option in the tools of the TV... but, all I'm seeing is a bunch of "+" symbols all over the place... and not sure how to work the convergence. Help???
    Sergeant:
    Champion:
  • 375 Answers
You need to replace the convergence ic'S inside the unit
Posted on Aug 18, 2007
  • g w Aug 18, 2007
    the convergence amp ic's start with stk- numbers
SOURCE:
Blurred picture or not clear picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
My picture on my Hitachi 51F710A has a very strong red/pink tone over the entire screen but is slightly worse on the left had side. I've tried all the adjustments on the menu including the magic focus but...
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 19, 2009 | Hitachi 50UX57B 50" Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 55P8288A Green tinge over entire picture
  • Screen looks 3D
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Convergence controls
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Sep 20, 2008 | Philips 51PP9100D 51 in. Television
My HD TV is no longer showing a clear picture
Sure sounds like the CRT fluid is cloudy and needs to be replaced.
If its not the fluid the convergence chips are bad.
  • Screen looks 3D
2c07611.pngSolution
Aug 03, 2008 | Philips 51PP9100D 51 in. Television
Philips 9P6040C 60 in. Rear projection
Here are some of the most common symptoms.
  • Screen looks 3D
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
