Question about Kenmore Elite 45986 Front Load Washer
Drain Problem My washing machine will not drain. I followed the instructions included in the owners manual. Doubled checked the drain hose and all seems fine. Is there another place to look if the drain is clogged?
  • basketcase Aug 18, 2007
    Since my wash machine and dryer are close together, and I am not strong enough to move them myself. I decided to try cleaning out the drain trap first. Yes it was messy, but I used a trash bag to catch the majority of the water. The drain access was easy to find. When I opened it I found two golf tees and a quarter in the basket. The propeller on the pump is really small and I didn't find anything around it. I put everything back together and turned on the machine with nothing in it. It just finished the wash cycle and is draining as I type!!!!! I have my fingers crossed that it will finish the cycle without any problems.
    I forgot to say THANK YOU!!! You saved my weekend.
  • 5,911 Answers
The first thing you need to try is to pull a vacuum on the drain hose to see if you can pull water from the tub. You can do this by using a wet/dry shop vac and connecting it to the end of the drain hose. If the water drains from the washer you may not have a clog. It may actually be a bad drain pump. If water does not flow, or is draining slowly you will need to check the drain pump AND the hose between the pump and wash tub. You can accomplish this by removing the lower kick panel under the door. There are three 7mm screws under the bottom edge. The drain pump is located on the right hand side of the machine or directly in front under the wash tub. It is the ONLY pump in the washer so it should be easy to find. There is a clean-out access that you can remove to clean out the pump impeller. Removing this access will cause whatever water is remaining in the tub and drain lines to come gushing out. That's why it is important to try to remove as much water as you can, FIRST. Even if draining the tub with a vacuum is slow, let it drain. When removing the drain access, look for anything that may be obstructing the impeller. I have found items as small as a Q-tip can stop the pump (believe it or not). In a nut shell: Pull a vacuum on the drain hose - 1. WATER DRAINS EASILY - failed drain pump or obstructed impeller. 2. WATER DRAINS SLOW - Obstructed drain pump and/or drain line. 3. WATER DOES NOT DRAIN - Serious obstruction somewhere in the drain line BEFORE the pump (usually a sock or wash cloth that has worked it's way between the basket and wash tub). *You will notice the drain hoses collapsing as you pull a vacuum if there is a serious clog. Let me know if this helps you.
Posted on Aug 18, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 18, 2007
    I'm glad your problem wasn't a serious one and that it didn't cost you a bunch. Now you know what to expect if this happens again. Check those pockets and good luck.
Thank You!!! Though this was posted in August of 2007, I found it useful today! My washing machine was making a noise so I thought I would stop the cycle to check what was "clanking" on the glass. When I tried to resume the wash it showed an error code of F-01. I went to the manual and tried the manufacturer's solution which was to turn in on and select drain/rinse cycle. After numerous tries I decided to do an online check and THANK THE LORD!!!! I found this web site. After scrambling around for a while trying to locate the correct tools to remove the lower kick panel door, I was victorious in removing it. I then proceeded to undo the clean out valve's lid and to my suprise, it had obstructions (one necklace, a part of an earring, a neddle, several pellets from my son's pellet gun and to my suprise...a AA battery!
I followed jsrocks516's instructions and am proud to report that my washer is working again!!! Thanks Again!
Posted on Jul 21, 2008
SOURCE:
After the wash cycle there is still water in tub and cloths are wet, I have to run spin once or twice more to get out all the water
Your user's manual should tell you how to clean the drain line for your washer. Also, check your drain hose to make sure it is not kinked. If you are mechanically inclined, you can unplug your washing machine and then remove the back cover. You will see your drain hose and follow it to the drain pump. More than likely your drain pump is plugged or somewhere between there through the drain hose. Draining of a washing machine is a timed event. So if it does not drain, there is a clog somewhere in your washing machine. This video gives you a basic idea of how to do your pump:
But do this one first to check your discharge hose for clogs:
Nov 20, 2017 | Washing Machines
Machine did not drain and when rinse cycle came around it filled with more water, now full of water not draining, and the dial will (tick tick tick) round and round and round until I manually stop it!!! ...
Hi.
According to the description, the parts that may be responsible are pressure switch, drain system, control panel.
Testing will start from the drain system. The drain hose at the back must be checked making sure that there is no blockage and that hose height is set according to manual. If hose is set incorrectly water may flow back from the drain hose into the tub. The consequence is the drain part of the cycle not ending because of siphoning. The drain filter connected to the pump must also be checked. Drain blockage would not explain water filling the tub while machine is supposed to drain, but the filter must be checked in any case because it may be part of the problem. If the machine is front load the drain filter access is usually in front at the bottom, if the machine is a top loader, depending on the model the pump is accessed from underneath or from the back of the machine.
After checking the drain system inspect the pressure switch. The pressure switch is the device that detects the water level. Most washers have the switch located in the control assembly, near to the timer. To access the switch the machine must be partially disassembled. The pressure switch looks like a plastic disk with three or four electrical connectors. The switch is also connected to a long thin rubber hose that extends inside the tub. Before replacing the switch try cleaning the rubber hose and the switch nozzle. Excess of detergent may clog the switch, causing malfunction that often affect the drain and spin part of the cycle. The switch is not an expensive part and it is difficult to test. The switch is tested reading Ohms ( or Volts) at its terminals with tub full and empty. Testing must be done by a trained technician. If cleaning the rubber hose does not do the job I suggest replacing the switch.
If the drain system and pressure switch are fine the next step usually consists in replacing the control module. Before replacement the module should be test reading volts during cycle, checking test points in service manual or at least performing a diagnostic cycle. Instructions on how to run a diagnostic cycle are detailed in the tech sheet. Unless previously removed the tech sheet is usually tucked inside the washer, often inside the control assembly (Maytag, Whirlpool and more).
If the machine is installed in a vehicle, then it is a built in model. To be serviced the appliance must be moved out from its housing. The options for the user are either DIY or calling the number listed on the owners manual to get professional support. Depending on the model the instruction to mount or remove machine from housing are illustrated either in the owners manual or in the installation manual provided with the owners manual.
Regards.
Ginko
Jan 04, 2012 | Washing Machines
Where does the grey hose connect? I'm not sure if
First we need to know what diameter said Grey Hose is? I assume you are speaking of a Washing Machine?? If so, typically they are equipped with 3 hoses as follows: One for Hot Water Supply and a Matching hose for Cold Water Supply. Both of these hoses are equipped with 3/4 Inch Female Housse Thread connectors identical to a Garden Hose. So that delegates the Third Hose to DRAIN. It is LARGER and usually is attached inside the Washing Machine to the Water Pump and passes through the rear cover and ultimately must be formed into a "U" bend and inserted into the Drain. It is necessary to secure this hose to the Drain and Supply device so that it cannot blow out of the Drain while the Washing Machine is Pumping Out. All Washing Machines come with User Manuals and Installation Instruction Sheets. Like Automobile Owners Manuals, they should be read cover to cover and stored for future reference. You can find most Washer and Dryer Manuals online. Use Google Search to find them.
Nov 18, 2011 | Health & Beauty
My GE Washing Machine fills up with water to the appropriate line and then begins the agitation cycle... The water immediately begins to drain to the point the water turns on to fill the tub again... this...
is the drain hose connected to a drain standpipe or laying in a utility tub , or a floor drain check owners manual for proper drain hose height and requirements if drain hose is lower than the height of washer it can auto siphon out of drain hose ,,,,, is the drain hose sitting in stand pipe freely or is it connected to stand pipe with no air gap
Jan 24, 2011 | Washing Machines
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does code F mean
F is part of a system fault code. There should be additional characters (numbers) in addition to the F.
Here's what I get from a Cabrio Owner's Manual if there are numbers after the F:
F## code (F-type error code) appears in display
System error code. Press START/PAUSE once to clear the code. Then press START/PAUSE again to restart washer. If code appears again, call for service.
I called Whirlpool at 1-800-442-1111, and according to customer support the manufacturer intentionally no longer provides descriptions for F codes (though there are still a few owners manuals that will describe something like F21 = Long Drain). Check to see if your owner's manual provides any F code help in the troubleshooting section.
Generally, what I was told is that F codes indicate customers need help from a technician. Not always completely true, and really not very helpful--especially if you want to attempt to avoid scheduling service.
Since there are numerous F## codes, please provide the specific code number if you desire further assistance.
Here are letter codes Whirlpool provided in the owners manual (copying from a PDF works poorly):
oL (overloaded)
appears in display
Load too large. If an overload is detected, the washer will drain any water and
detergent in the washer. Remove several items and add HE
detergent. Close lid and press START/PAUSE.
uL (unbalanced load)
appears in display
Load not balanced. The washer is
running a load-balance correction
routine.
Allow the machine to continue. If the dial is flashing and the
machine has stopped, redistribute the load, close the lid, and
press START/PAUSE.
LF (too long to fill)
appears in display
Washer taking too long to fill.
Drain extends more than
4.5" (114 mm) into standpipe.
Check plumbing for correct drain hose installation. Use drain
hose form and attach securely to drainpipe or tub. Do not tape
over drain opening. See "Installation Instructions".
Ld (too long to drain
water ) appears in
display
Washer taking too long to drain
water. Drain extends more than
over drain opening.
Lower drain hose if the end is higher than 96" (2.4 m) above
the floor. Remove any clogs from drain hose. See "Installation
Instructions".
etc...etc...
Jan 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My kenmore elite he3t will not spin the water out - takes several tries. I've confirmed that the drain line is open, trap is clear, and hose is clear. I have yet to attempt accessing the pump. My owners...
Your owner's manual won't give you that information. The following link explains how to access and check the pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
This is a very simple process. A wet/dry shop vac would come in handy of you have one, though. There's about a gallon of residual water that remains in the lower wash basket, drain lines and pump that will come spilling out of the pump unless you remove it beforehand. It could save you from having to clean up a mess.
If you clean the drain pump and check ALL the drain lines (this includes the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump), and you still have problems, then you may have to replace the pump.
If the pump is damaged and cannot pump at the correct volume to complete the drain cycle, the washer will not complete the wash cycle or drain. You may experience an error code of "F02" or "F21" (Long Drain Error), depending on your washer model. The pump will require pump replacement if this occurs.
The following link explains how to replace the drain pump (if required):
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I hjave listed also have helpful exploded view parts illustrations to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 13, 2010 | Washing Machines
Washing machine isn't spinning clothes.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Nov 20, 2009 | Kenmore Elite 45986 Front Load Washer
Water does not drain way
First check the drain hose is not blocked.
If you do not find anything in there, then you need to access the drain pump, opening the panel at the bottom on machine front, undo the hose from the pump and clean the hose. You find detailed instructions on machine owners manual.
Apr 16, 2009 | Hotpoint First Edition WMA20 Front Load...
Leaking, not found in owners manual
If it leaks during drain or spin cycle, it means that your exit hose has come loose or has a break. This can be replaced easily.............
Jan 02, 2008 | Maytag SAV515DE Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
252 people viewed this question
Sal De
fordexpert
yobo007
yobo007
