Question about Sony Xplod XM-1652Z Car Audio Amplifier
Help its aggrovating!!!
My amp was working just fine then one day it started to overheat alot then shut off n come back on. then one day it cut off completely so i changed the fuses and now the amp comes on then when the bass hits the led light turns red... plz help thnxs
    Scholar:
  • 130 Answers
Maybe the cooling system has become blocked up with dust and such? That's what happens with my laptop, I have to take it apart every couple months and clean out the cooling system or it overheats and shuts off.
Posted on Aug 17, 2007
Take a wire and put it in ur butt then take it out and lick it.. voila !
officially FixYa !
Posted on Nov 13, 2007
SOURCE:
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
What do i do after my microwave overheated and shut off?
they have a built in overload thermo cut out when it is on for a long time it will cut out cool down and should be ok to use again
May 28, 2012 | Emerson Microwave Ovens
What is it when the truck over heats cut off and wont start back up
Perhaps this is a safety mechanism in your car. Once it gets to a certain temperature, it shuts itself off. There are alot of cars out there that once they overheat, and turn the car back on, it won't turn over.
Mar 25, 2012 | 1999 GMC Jimmy
Music plays for a while, depending on the weather and how hot it is and then it just cuts off and the protect light comes on. Had this amp for 4 years and no problems till now. Some days I can listen the...
check the cooling fans inside the amp i suspect that they are not working properly and this causing it to overheat which will shut it down via a thermistor to prevent damage
Aug 18, 2011 | Infinity Reference 7541a Car Audio...
I have a Kenmore Dryer Mod#110 62722101. It will run about 10 minutes and shut off, after a cool down period it will restart but only run about 10 mins. Heats, fine, tumbles fine. A few days before this...
If it runs after a cool down period, then the high temperature limit is part of the cause. What is causing the high temperature limit to overheat is next.
Strong stream of air should be felt coming out the exhaust, make sure this exhaust air works or the burner part will overheat and cut out the flame/burner on hight temp safety.
With good exhaust air varified, the drying air operating temperature sensor needs to be checked, this cuts power to the burner. The sensor must open electricaly when satisified on temperature and should be properly mounted for proper sensing of temperature.
Bottom line: Check the hot air and its control
Jun 04, 2017 | Dryers
Bike shuts off???
if when your bike gets to riding temp. and, you turn it off; and, then restart... if the crank speed is slow replace your battery if your crank speed is normal replace your ignition module (batteries can be recharged and, measure 12 volts and, still be weak)
Amps can fall off (amps are what give the battery muscle to spin your starter ) ignition modules can be affected by heat and fail to maintain spark
Apr 29, 2009 | 2003 Suzuki GSX-R 750
JVC Car stereo with cd shuts off when volume is turned up
Hi Ithink , you are trying to push too much power to your speaker setup. Your cd, tuner, player, is only go as loud as the volume at half way setting. Your speakers are , probally good ones that want more power, and making your player overheat and making circut protection cut power. I would say, you should use it at 15, and that is as loud as it should be played to aviod distortion and overheating.
I'm guessing max is like 25 or 30, Is that so? You can listen to louder tunes by installing an amplifier. Or if you have an amp in your system it may be overheating, I would really like you to let me know if you have been trying use it at volume higher than half the maxium volume setting, so I know I helped, and you can start looking into power amp's. You can crank it up for good parts, but most players were not made to send alot of juice to good big speakers at high volume level.
Tell me what you think, tooldoc
Dec 05, 2008 | JVC AM FM CD DET FACE CAR STEREO
AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Amp cuts out when turned up
that amp cutting out like that means that its probably shot and it time to start looking for a new one
Apr 09, 2008 | Directed D800 Car Audio Amplifier
Sub cuts out when I switch to CD player?
It shuts off because the remote turn-on wire to the amplifier is connected to the power antenna wire behind your head unit. The power antenna wire is only activated when the tuner is selected. You need to switch the remote wire to the blue/white wire from the head unit (currently you're using the blue wire). This is the true remote output, and will activate the amp whenever the head unit is powered on.
Jul 06, 2007 | Alpine CDA-9885 CD Player
Sony Xplod XM-1652Z Car Audio Amplifier Logo
77 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
