Question about JVC AV-32D305 32" TV
Power problems my tv is powering on and off and will not stop until i unplug it, it is as if someone is constantly turning the tv on and off all the time.please help.
  • 1 more comment
  • lori_fehr
    lori_fehr Aug 17, 2007
    no, nothing stopped it except unplugging it, and when i plugged it in it it did the same thing. is there any way i can disconnect the power switch on the tv, i have the back off already
  • lori_fehr
    lori_fehr Aug 19, 2007
    only 4 years old
  • lori_fehr
    my tv is 4 yrs old
    Scholar:
  • 130 Answers
Something wrong with the power switch? Does it stop if you press any buttons on the TV (including the power button)?
Posted on Aug 17, 2007
  • Anonymous Aug 18, 2007
    depending on where the buttons are, and how they are connected, you may be able to unplug them from the main board of the tv, but if they are on the main board, the best you can do is rip them off or unsolder them, and I don't think you want to do that. How old is the TV?
  • Anonymous Aug 19, 2007
    It could just be fried, and every time it tries to start up, it shorts out or something and is forced to restart. I'd recommend you call Tech support for the manufacturer of the TV.
SOURCE:
Hey Axle, I have run into an issue that has stumped me. I have a 50" Vizio Plasma made in 2006 the model is P50HDTV10A. I am confident that how the problem occurred is lighting ran in on the TV. What...
TRY TO UNPLUG THE POWER CABLE GINIG TO THE Y BOARD THE ONE COMING FROM THE POWER SUPPLY SOMTIMES BLUE AND WHITE IF CLICKING STOPS Y IS SHORT IF NOT UNPLUG POWER CABLE FROM POWER SUPPLY TO X BOARD CLIKING SHOULD STOP IS YES ITS THE X BOARD THATS SHORT TAKE TIME TO UNPLUG YOUR TV BEFORE DISCONNECTING ALSO BEFORE RECONNECTING Y AND X WAITE ATLEASE 5 MIN FOR CAP TO DISCHARGE
Jun 08, 2010 | Televison & Video
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
Dec 10, 2009 | Televison & Video
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
TV is turning off and on while watching
The Outlet the TV is connected to is losing power (try switching to another outlet)
OR
The TV's power supply has a problem (I think loose component or bad soldering somewhere)
Jun 23, 2009 | RCA 27V520T 27" TV
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Fan runs constantly never turns off
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Toshiba 62HM95 62" DLP HDTV
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Power supply for dmtech wt20xt lcd tv
I have DMtech 20" with intergrated DVD and had the same problem- blue light lit on power switch but no response on power up.
I noticed that when the power cord was unplugged from the back of the TV the green LED on the power supply would brighten and consequently dim when plugged back in. Sometimes the blue light on the power switch would strobe very quickly but you had to look carfully for this.
I repeatedly unplugged the DIN type power plug from the back of the TV untill the green light on the power supply stayed a constant bright and there was no strobing on the blue light on the front of the TV, when I powered the TV on at this point the button worked again and the tv powered up with the silly tune then life in the screen. I did have to do this a good few times (I'm tenacious) but it did work!!!!!
Hope this helps someone else, cheers.
Apr 11, 2008 | Televison & Video
Tv will not turn on but it constantly blinks and will not stop
You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
Aug 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Blue power light constantly on...
possibly shorted crt drive ic on crt board.
Jun 14, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-32D305 32" TV Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
