Question about Averatec 6200H Notebook
My keyboard and mouse pad doesn't work; there also is something going on with the power up. it takes a couple attempts and i have to hold the power button. with a keyboard & mouse plugged into the usb ports it works fine.just a little unandy. kinda defeats the purpose of he laptop if you need to carry a keyboarx around with you. thanks in advance for any advice you may be able to offer.
  • rmartin994 Dec 30, 2008
    how do you do a system restore if the mouse or keyboard won't work?
    Novelist:
    Scholar:
  • 158 Answers
Sounds like currupt files to me have you tried a system restore point enter safe mode using f5 or f8 key then goto system restore in start menu, programs, Accessories, system tools, sytem restore if all fails copy all files needed onto an external hard drive and re-load windows on you laptop. hope this works for you
Posted on Aug 18, 2007
SOURCE:
Ge wired mouse scroll wheel doesn't work
John:
The screws to open your mouse are hidden under the glide pads on the bottom of your mouse. remove the glide pads carefully and you'll see the screws. put the glide pads on with a non-permanent adhesive (like contact cement).
Jan 17, 2013 | Computers & Internet
HID-compliant mouse
Not much description to go on so im guessing, right click my computer and go to manage or search device manager, click on mice and other pointing devices right click and un-install restart the laptop on boot up it will recognise a mouse and install it from there if the problem is still there then try holding down the Fn button and look at the top of your keyboard to something that looks like a mouse pad and press it as doing this will turn on and or off the mouse pad if the problem still persists then there is an indication of a circuitry fault and should consult asus to send it in for replacement or a computer repair work shop to have this fixed
Jun 27, 2011 | ASUS Computers & Internet
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
The feet broke that holds the keyboard up, where i can i purchase new feet?
Suggest anyone who has this problem pick up a pair of 'laptop legs'. They're designed to prop up laptops to improve cooling, but they do the trick.
E.g.:
http://cgi.ebay.com.au/Notebook-Netbook-Laptop-Cooling-Cooler-Ball-Leg-pad-/360269274791?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item53e1b8dea7
Apr 19, 2010 | Dell Wireless Keyboard Optical Mouse w0147
New cordless mouse slow to respond to "click": cannot control or direct movement: jerky, sporadic. Is this because I do not use a mouse pad?
mouse pad would help but you may have a virus so go to windows help and support and download the windows defender and run it, there have been a lot of bugs affecting mice lately however do try to use something that has a surface on it that would make the mouse work better if it does work better then buy a mouse pad next if it's still slow you can go to control panel and sped up the mouse and also into tools Internet connections and change the mouse properties there.
Feb 05, 2010 | Logitech Cordless Mouse
Re toshiba techra 8000
Some laptops have a touch pad between the keyboard and the edge of the laptop. This works like a mouse except you slide your finger around the pad to move the mouse pointer and the buttons next to the touch pad are the left and right buttons.
Other laptops have a small round button in the middle of the keyboard which is a mini joystick and it is used to move the mouse pointer around, it will have a couple of mouse buttons at the botom edge of the keyboard.
You can connect a normal mouse to your laptop, it is mush easier than using the laptop's touch pad or mini joystick.
Sep 16, 2009 | Toshiba PA3121U - Satellite Pro 6000,...
Emachines laptop e525 mouse pad not working at all so cannot use everything else starting up as normal
Look at the middle cover (above the keyboard). there are two buttons that touch the power switch, the one to the left enables/disables the touchpad. If it shows an orange light it is disabled. Just press it, and be careful not to hit it when turning unit on.
Jul 08, 2009 | E-Machines T5212 PC Desktop
Touch pad will not work
Hold down the FN button and up on the top of the keyboard there will be a button with a picture of a mouse. As your holding down your FN button hit the other button and see if it enables your mouse. Something should come up on the screen showing you that its enabling or disabling the mouse.
Feb 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
Gearhead Mouse's cursor not moving.
Gearhead is known for making cheap products that have low quality. I would immediately take this product back and go with something else. Sorry, the best advice I can give..
Aug 18, 2008 | Computers & Internet
Averatec 6200H Notebook Logo
583 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
