Texas Instruments TI-83 Plus Calculator Logo
Posted on Aug 17, 2007
Weird lines, characters, symbols etc.
My calculator turns on, but anything I type in comes up as weird lines, characters, and symbols. Nothing is legible. The screen does not say "Batteries are low." I have replaced the AAA batteries just in case; I tried them in other devices and they worked in them but I still get the mess on the calculator screen. Do I need to change the lithium battery? I've had this for a number of years and never changed that. Or is it software issue?
  • zimmer_steve Oct 02, 2008
    Changed AAA batteries, and now screen displays random mess of symbols
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Aug 27, 2007
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
20740
Points
57
It sounds like you need to put in a new set of back-up batteries. They can be found behind where the AA batteries are.
My ti-84 calculator show unreadable code only?
Honestly, I do not understand what you mean. This calculator is designed to run commands one after the other. You may stack a few of them only if you do not need the output of the first ones.
Anyway, the memory is limited and that includes the register where the current line is stored. If you enter too many characters, the calculator stops accepting them and the cursor will change shape.
If memory is full you can no longer do anything. One simple way to regain some working memory (RAM) is to clear entries (the commands you typed). Press [2nd] [+] to enter memory managem2nt and select the command ClearEntries. You can also select ClearAllLists, or Reset. For the last choice you can then choose to reset ALL RAM.
Every time I put pc into sleep mode when it comes out the entire left side of keyboard comes up with weird symbols and characters.
May i know for how long you have been facing this issue now?
And what exactly do you mean by "entire left side of keyboard comes up with weird symbols and characters"?
The on-screen keyboard comes on your screen?
Have you enabled the On-screen keyboard feature in control panel?
For further assistance, contact us at HNetworking.com or call us @ 850 309 7078
Admin
HNetworking.com
The left side of our ti-84 will not display after
Would it help if I told you that all the precision you are apparently looking for has no meaning?. In any number resulting from a scientific calculation only a limited number of digits are truly significant.
If you are entering characters (numbers, symbols, letters, etc.) the calculator keeps accepting them until its memory is full. At this point the cursor changes and go from a solid rectangle to a checkerboard-like rectangle, and you cannot enter anything anymore.
But if you are calculating some meaningful expression, the calculator displays the result according to the display mode you selected: Normal, Scientific, or Engineering). However, even in normal mode, if a number is too small, or too large, the calculator displays it in scientific format.
Scientific format
This format is as follows
  1. A minus sign if result is negative. If positive (+) is omitted.
  2. One digit
  3. Decimal mark (.) or (,) according to configuration
  4. A certain number of decimal digits (maximum 9)
  5. The E to symbolize ( times 10 to the power of)
  6. A minus sign (if exponent is negative), nothing if positive
  7. A maximum of 2 digits for the exponent of the power of 10. The maximum exponent you can have is 99
Let us count the number of possible characters in a display
-1.123456789E-12. That is 16 character slots.
Try playing with the number 987654321123456. All you will see is 9876543211E12. The 23456 sequence disappears, and all that "precision" is lost. Why, may I ask, should you worry that your calculator is not displaying more that 13 characters on the left.
This is what I understood from your one-liner of a question. And because it is a rather cryptic one-liner, I may have gotten the whole problem wrong. If that be the case, do not just shoot down the answer, post a comment to the solution describing what you are trying to do. If it is a bona fide worthwhile concern, I will do my best to help you with it. If on the other hand, it is jus plain idle doodling I will leave it at that.
Texas Instruments Ti-83 Plus Help
possibly water damage... there might be an indicater of this such as one on a cell phone. behind the battery possibly, a small sticker that changes color when dampened.
as for solutions... warrenty? lol
Graphing multiple equations
The symbol on the left of the Ysub1,2,etc. determines what type of graph it is. move the cursor to the left of Ysub1,2,etc. and hit enter
Weird display problem.....HELPME PLEASE!!!
I had the same problem Jozhy. I fixed it by re-upgrading the OS using the latest version of TiLP (TILP2 version 1.04). When I tried it using the version of TiLP 2 that I had it didn't fix the problem. I understand that the version before the one that was released a few months ago didn't flash the OS correctly. Try it again after downloading the latest program.
Random characters lines and pixels
I've had a similar problem in the past with my TI-86. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons every few minutes.) It works great, and the calculator is fine unless you leave it unused for a month or so. A similar solution may work for you.
Calculator Stuck
Hi. I suspect your calculator BIOS is corrupted. Still looking for the download for that though. Do you have a USB link cable? If so, plug in your calc and check your device information. See if anything comes up.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
