Question about KitchenAid KSRS25CNBT / KSRS25CNLK / KSRS25CNWH / KSRS25CNBL Side by Side Refrigerator
Filter My refrigerator is a KitchenAid KSRSQXWH10 serial Number SB1814914 and I need to know if there is a filter for the water and ice and where it is located. The water coming in is well awater and it tastes great out of the tap but the water in the refrigerator is terrible.
    Novelist:
  • 87 Answers
Water filters for most refrigeration cabinets are located externally to the cabinet as they are quite large. If you have one you would know. If you dont have one fit one as they make a large difference. Once fitted make sure you run the water through. Hope this helps.
Posted on Aug 17, 2007
SOURCE:
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Frigidaire KSRA22 CNWHOO Side-by-Side refrigerator, Serial # SS1241434 I just changed the filter in my Frigidaire refrigerator. It had stopped making ice when the filter light came on. However, now...
Are you getting any water.
If you push the tab for water any you hear a buzzing or humming sound with no water then it could be you water pump which is located at the back of the fridge.
Just follow the water line and you will find it .
It's a small pump
May 26, 2017 | KitchenAid Superba Architect KSCS25INSS...
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Apr 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
I have a Kitchenaid Superba and when ever we turn on the ice maker. it says our filter needs to ebe changed. is that a problem? However before even when the filter was bad it still made ice. whats wrong?
Most refrigerators with filters will not work...with a bad filter...they will work initially ...for a while after the filter indicates it needs to be changed but over time the filter can become completely clogged...and no water will flow...also the impurities that were being filtered out...are now in the water and the ice and can accumulate in the ice tray...or at the spot where water is dispensed into the tray...with real hard water calcium can build up and inhibit water flow. I would definitely change the filter..... I had the same problem and the filter and the monitor for the filter are tied into the circuitry...so yes it can definitely stop the water flow.
I hope this helps....good luck...please rate me...The Fang
Mar 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
KitchenAid KSRS25CNBT / KSRS25CNLK / KSRS25CNWH / KSRS25CNBL Side by Side Refrigerator Logo
97 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
