Question about Jeep 10 x 20
94 jeep cherokee manual clutch fluid tube
I have a 94 jeep cherokee with a manual clutch, i need to replace the fluid tube between the master cylinder and the slave. it has a small hole in it. First question: is it plastic or metal with a plastic cover. does this fluid tube come off and if so How? the whole assembly is over 275 dollars canadian and i would rather just replace or repair the hose. thanks
The clutch hose on this model is all plastic with quick release metal ends. New master, slave and hose assemblies start at $145 to $240. There is an article on replacing the slave with 3/4" bore air cylinder for under $30. You could easily replace the line at this time using a simple compression fitting to connect to the stub of your old line. For that matter you could easily repair the hole with the same fitting available from any hardware store.
Posted on Oct 22, 2008
  • 883 Answers
Easist fix is to visit a car junkyard and find a 94 jeep cherokee (or close to same year). remove the tube and pay the junkyard dog on the way out. Chances are the tube in the junkyard may also be developing a hole, so carefully inspect it before settling. Many tubes on cars today are metal that are covered in plastic. To remove it, keep in mind that it was installed at the factory, so removal is just the reversal. Look for a swivel connector at one end of tube (or both ends). This swivel connector is identified by a hexagonal "nut" and a "break" immediately next to it. This is actually a compression fitting that when tightened, forces two metal surfaces against each other that are tapered inside (look for this taper once removed). Now using an open-ended wrench, turn the nut loose while holding back rotation on the tube.
Posted on Aug 18, 2007
  • Marty marty Sep 03, 2007
    do you still need help with this?
SOURCE:
No hydraulic clutch engagement in 1996 Jeep Cherokee Sport 5 speed
pump clutch watch fuild in master, it should go down and up with each pump and release. the master can be by passing. if the system has been drained you may have a air bubble in master. to remove air use a nose suckion ball, put in the bottom of master. be sure to suck it in the up and down spots
Feb 07, 2018 | Cars & Trucks
94 Chevy 2500 Clutch Engagement?
You probably have a hydraulic clutch. A hydraulic clutch has both a master and a slave cylinder. The slave cylinder engages/disengages the clutch plate. You might be low on clutch fluid in the master cylinder, or the system may need to bled similar to bleeding brakes. Worst case is you need a new clutch, pressure plate, and throwout bearing. They should all be replaced when doing a clutch job.
Aug 23, 2012 | Cars & Trucks
1989 Jeep Cherokee - replaced clutch master cylinder, clutch looses resistance sometimes. Goes all the way to floor.
they hav a nuetral safety switch or depressn the pedal is common--send issue to magicmechanic in orlando-hes a mastertech with any car or system--chec out the sites Q n A first
May 20, 2012 | Cars & Trucks
How do i check the master cylinder for the clutch on a 94 jeep cherokee sport? the clutch pedal drops to the floor with no pressure. i'm trying to find out where the master cylinder is and how i can check...
the resivour is the smaller circular pot next to the brake mastercylinder on the left if your looking from the front. most likely caused by a bad slave cylinder
Nov 04, 2010 | 1994 Jeep Cherokee Country
Clutch won't disengage.
the mechanic should check the master cylinder assembly of the clutch check if the the rubber cups and the spring is still functioning or good if worn out or destroyed then re place . After checking check the reservoir if there still is a fluid if none then refill.there are two cylinders of the jeep there for you have to check it twice. Since you have check the transmission .But it has no problem then it could be the master cylinders for when you pressed the clutch it will stall.
Aug 22, 2009 | 2001 Jeep.5 Cherokee 2WD
Clutch needs bled
clutch and brake fluid should be change every couple of years, Since the fluid does attract moisture, and degrade the efficiency of the brake and clutch action.
May 19, 2009 | 1988 Jeep Cherokee
1993 jeep cherokee clutch
Take a turkey baster or similar item and **** the fluid out of the clutch master, refill it. Then open the bleed valve on the slave cylinder, have someone step down on the clutch, close valve. Repeat several times till fluid is clean coming out. Do not permit the master to run dry while bleeding. Top off when finished.
Apr 29, 2009 | 1993 Jeep Cherokee Country
How do I bleed hydraulic clutch in 1991 jeep wrangler
There is a bleeder on the drivers side of the transmission follow the tube from the clutch master cylinder if you cannot find it. Pump the clutch up and hold it down then open the bleeder repeat till air is gone. May have to bleed again after driving a bit. If you want to bleed the clutch master cylinder run a tube from where the line goes into the cylinder and take the cap off and run the tube into the fluid (make sure its in the fluid) then pump the clutch slowly until no air bubbles. I just replaced my clutch master cylinder this is where the information comes from hope it helps you out!
Mar 04, 2009 | 1991 Jeep Wrangler
94 jeep grand cherokee laredo brake problem
Hi there!
Check for leaks at the slave cylinders and flexi hoses.
After several attempts of losing pressure - check the brake fluid level in the master.
If you arn't losing any fluid, You've got a damaged seal in the Master cylinder, or are drawing air in due to improper adjustment (excess travel) of slave cylinders.
Are you trying this with engine running? - How does this affect it (using servo assist)
Jun 15, 2008 | 1994 Jeep Grand Cherokee
Jeep 10 x 20 Logo
636 people viewed this question
Top Jeep Optics Experts
Marvin
Marvin
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you a Jeep Optic Expert? Answer questions, earn points and help others
