Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Lid Switch I have a kenmore washing machine model number 11024732300. I just pick up a new switch but this one looks differnt than the one I took out. I was given part number 3949238. It has a metal tab on top but other than that it apprears to be the same. My real question has to do with removing the top panel so that I can access the switch. Can I just pop the end tabs underneath the top panel to lift the top up?
  • Anonymous Mar 21, 2014
    I need to raise the top panel to be able to remove the lid switch.
  • Anonymous Mar 27, 2014
    I wan't to get the top control panel off
  • 5,911 Answers
First of all, unplug your washer before attempting to remove the console. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Once you have the console removed, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps: 1. Under the console you will find the lid switch connector. Unplug the switch from the connector. 2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release. 3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first. You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps: 1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips. 2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in. 3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console. I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Aug 18, 2007
SOURCE:
Any recalls on Kenmore Model # 110.20022012 Washing machine?
I think that your "LID Switch" is broken, go to www.sears.com/parts and put your model number in and you'll see the lid switch listed.
Aug 28, 2014 | Kenmore Washing Machines
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
How to replace lid switch kenmore 110 22922 washing machine
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the cabinet.
Then see the following for how to release the console and pull the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=9b19162f839199d33f88dac696ac636c
May 07, 2010 | Kenmore Washing Machines
How to replace the lid switch for a top load kenmore washing machine model 110.92480200 part#1170635?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92480200
Look at the top and cabinet section and you should see how the switch mounts.
A concern that I have is that the part number on the Sears site for your washer is
Switch, lid Number:3352630Substitution:285671which isn't the part number that you quote.
Oct 12, 2009 | Kenmore Washing Machines
Kenmore washer model number 110.22642100 won't spin
check the lid switch. if the machine is agitating and washing but won't spin it is probably the lid switch. this is the switch on the top front right of the machine with the lid open. you will see two phillip head screws holding it in place. easy fix is to unplug machine and take screws out of swith, clip wires and use wire nuts to connect another switch.
Apr 07, 2009 | Kenmore 22642 Top Load Washer
The part that gets pushed down by the lever when the washing machine lid is closed broke off my older Kenmore Washing Machine. Can it be replaced or do I need a new washer?
Its the lid switch i think, of course you can get a replacement and fit it yourself. You need your model number, etc to look below.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Mar 13, 2009 | Kenmore 15864/15862 Top Load Washer
Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont drain
Go to sears web site and enter model number of machine and look for lid switch. The cabinet of the machine needs to be removed to replace this switch. Go to Appliance Guru for details of removing the cabinet
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE 80 SERIES MODEL # 25842400
This often appears to a more serious problem than it really is. The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949238) and the lid strike will be listed as item number 20 (part #350733). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 07, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
309 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
