Question about Insignia NS-DV2G MP3 Player
Player freeze on "Build library.."
Hello, I believe I have a corrupted file on my Insignia MP3 player. Whenever I turn on, plug in, etc. the player, it freezes on file 168 while building the library. Because of this, it never gets to the MSC mode so that I can delete the file. Does anyone know of a way to stop this initialization procedure so that I can access drive and remove the corrupted file? Thanks.
  • n9oah Jan 15, 2008
    Same problem with file 332. But the solution is not possible. If I could get to the menu to initialize the memory I could fix it. But I can't.
  • 3 Answers
The answer is to go to settings click on information and go to erase internal memory ....that is the way i fixed mine
Posted on Sep 09, 2007
SOURCE:
Shouldn't have Formatted shouldn't I?
Hello
Try resetting the device by pushing a pin into the small hole for about 3 - 6 seconds. You can also try to switch on the mp3 player and format it on the mp3 player itself if you have this function. One of these to solutions should work either way.
Best regards
Oct 18, 2009 | Creative Labs Zen Nano Plus MP3 Player
I have the Insignia sport mp3. It freezes when I try to play a song. It seems stuck on "pause." When I try to get it to play it just freezes and beeps. I have turned it off and back on. I can get to...
If your subscribtion to rapsody (or best buy, whatever they call it) digital music store ran out it will do that to any song you got from the store until you renew your subscription. Try putting a song on there that you own (you didn't download from rapsody) and it should play. I wouldn't bother renewing the subscription though, the store has a poor library (I couldnt' even find don't worry, be happy). Just download your songs from limewire
Jan 03, 2009 | Insignia Sport MP3 Player
Frozen/wont charge/turn on
when your mp3 player freezes hold the power switch like your going to turn it off and holdit for roughly 10 seconds. that should reset the mp3 player
Aug 24, 2008 | Insignia Sport MP3 Player
My Insignia 2GB Video MP3 Player is frozen
try to turn it on and if it freeze hold the power button for 10 sec to reset it.
Jul 12, 2008 | Insignia Sport MP3 Player
Downloading Music to MP3
I dont believe you can use iTunes for this mp3 player you will need to use window media player to sync
Apr 21, 2008 | Coby MP-C858 MP3 Player
Mp3 player freezes while synchronizing files
If its frozen for everything go to utube 4GB INSIGNIA PILOT (FROZEN)
Feb 26, 2008 | Insignia NS-DV2G MP3 Player
Mp3 player
hello:
My mp3 player is creating a problem in deleting and saving songs from memory.. Whenever i tried to delete any existing file,, it deletes its once..but when i reopen. i find the same file in the library.. And when i tried to load anything in it..it stop in the middle of downloading..
I m nt getting where is the problem ? I tried to delete whole files from my mp3 players but some fles are nt getting deleted..Can anyone help me in this matter please ?
Jan 21, 2008 | iLO MP3 Player
I've had 2 crashed iriver X20
Hi. I just had solved my Build Library problem. Use my solution on your own risk.
The solution is the following:
1. open up a player (find 8 screws, not 6, 2 of them are on the left side of the player under the round stickers)
2. jently take off a circut board. (you need to access its bottom)
3. Find a memory chip. It is labeled like "samsung k9hbg08u1m"
4. find chip's key meaning start of pin numbering (small circle on the corner). There are 48pins. 24 on the left side (1-24) and 20 on the right (48-25) see chip's manual http://catalog.gaw.ru/index.php?page=document&id=11348 page 4
5. On the right side find pins 32-29 (find them as the second 4 pins from the chip's circle key opposite corner)
6. Connect them together with some metalic wire (don't touch two middle pins on the right side of chip, it is chip's power supply).
7. Holding those pins together connect USB cable to player's socket.
8. After a while player will show error on its screen, get metallic wire out of pins, and then the player will be available as flash storage on the PC.
9. Format flash storage with quick format.
10. Disconnect and assemble the player back.
11. Connect to PC and upload new music.
12. Feedback to fzymarev()yandex.ru
Oct 12, 2007 | iRiver X20 MP3 Player
Insignia 4MB MP3/video player
File allocation table on your player is corrupt. try to use the following method to transfer files from your player to your c drive... else... all is gone...
You can use Windows Explorer to transfer files to and from your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your files to/from your c drive to the new drive for your player. You'll notice that when you use Windows explorer to delete the files on your new drive for your player that it doesnt remove them from your Music Library on your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. [email protected]
Mar 13, 2007 | Insignia IN-MP3256 MP3 Player
Insignia NS-DV2G MP3 Player Logo
288 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Steve Allison
Steve Allison
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
