Question about Sony DAV-S300 System
"No Disc" Just recently my DAV300 has not been reading discs. It will simply say "no Disc". Sometimes I can get them to play, but it will randomly stop and "C:1300" flashes on the bottom of my tv screen. Can you tell me what's going on and how/if it can be fixed?
  • Anonymous Jun 20, 2008
    I used the advice offered by entering the disc calibration menu and only got as far as the single layer test as the ERROR!!! TEST ABORTED message appeared in the menu screen, then opened draw and REMOVE DISC appeared. It seems to be a common issue with this model which is a real shame as it had a great sound and performed perfectly for years until the dreaded C; 1300 and NO DISC began to appear with more frequency until it stopped working completely. maybe my machine has several issues as well as those described which requires an engineers expertise. Anyway this means of access to the main menu dose work so give it a go, i may just have left it too long to do any good.
  • Sony Master
  • 924 Answers
This is much more simple test than that. I assume that the unit only has issues with a DVD. Insert a CD. If that plays, you have an Optical Pickup(laser) that's bad. The servo system and audio path basically follow the same path, to a point. The wavelength of DVD and CD are different, therefore, the Optical Pickup, has two lasers in one unit. Most likely, you are not using CDs as much as DVDs. If the CDs play, but not the DVDs, 90% chance, the pickup is bad. There are really no adjustments in CDs or DVD players anymore. I was an Authorized Service Center for Sony. The CDP-101, was the first player to hit the market. It had.....4 hours worth of adjustments! These products have come a long way in the last decade.
If you are interested in having your DVD player repaired, please contact me at my website, audioserviceclinic.com. You may contact me there. Thank you.
Posted on Aug 03, 2015
Here are a couple solutions:
How To Recalibrate DVD Player
Summary:
For those that are having the skiping up and unreadable disk problems try the following calabration. I did it last night and now my DVD's are much clearer and I'm hoping the skiping problem is gone.
For those that have the lip sync problem Sony should cover this for no charge, you just need to push them a little. This is a firmware update, have a look at the other posts at this web site to find the firmware revision that you need.
HOW TO PERFORM THE CALIBRATION
Make sure that the DVD player is turned OFF and in the stand-by mode with the little red LED glowing above the on/off button.
To enter the service mode/test mode, press Title, Clear, and Power on the remote.
This will produce the following menu:
Test Mode Menu
0. Syscon Diagnosis
1. Drive Auto Adjustment
2. Drive Manual Operation
3. Mecha Aging
4. Emergency History
5. Version Information
6. Video Level Adjustment
Exit: POWER Key
What each item does;
Syscon Diagnosis = Leave this for service technicians.
Drive Auto Adjustment = Automatically calibrates DVDs and CDs.
Drive Manual Operation = Manually calibrates DVDs and CDs with prompts for permission to skip, execute and/or proceed after each adjustment is made or skipped. Offers a fascinating look at all of the many adjustments made, but this method is time consuming.
Mecha Aging = Allows auto repeat mode for testing purposes.
Emergency History = Shows the number of hours on your machine.
Version Information = Shows firmware version.
Video Level Adjustment = Test pattern.
Press #1 (Drive Auto Adjustment) on the remote and the following menu will appear:
0. All
1. DVD-SL
2. CD
3. DVD-DL
4. SACD
Exit: RETURN
Press #1 (DVD-SL) on the remote and insert a Single Layer DVD when the drawer opens.
Even though you may be interested in calibrating only a dual-layer DVD, do not skip the single-layer calibration procedure. For some reason, the player prefers to first calibrate a single-layer DVD before proceeding to a dual-layer disc. Error messages may result if the single-layer calibration procedure is not performed first.
Press the enter key and the machine will begin to calibrate all of the playback features. When calibration is completed, follow the onscreen instructions to return to the above menu.
When the Drive Auto Adjustment menu returns, press #3 (DVD-DL) on the remote and insert a Dual Layer DVD when the drawer opens. Follow the instructions as noted above.
When calibration is completed, follow the onscreen instructions to exit from the Test Mode Menu. Now you can turn the player back on and try your dual layer discs to see if the layer change has improved.
If you have any concerns about trying this service mode calibration, leave it for an authorized service facility
Other solutions:
1. To reach this test menu on a DAV-S300, press and hold the "STOP" and "Muting" button on your DVD Player (not remote) and turn the volume nob clockwise about 180 degrees. You will see a flicker. A blue test screen will appear, allowing you to calibrate your DVD. Please note that if you have no technical experience, messing around in this menu can cause serious damage to your DVD. The calibration option will be under: option 1, Disc Drive Auto Adjustment (or words to that effect). Be sure to calibrate a single-layer disc first, then dual layer -- you need to calibrate both types. Good luck.
In order for the STOP + MUTE + VOLUME sequence to work, your player must be ON, but have no disc present. You need to empty the tray, power off the S300 and power it back on. Wait until the INSERT DISC/NO DISC prompt appears. Then try the SMV sequence. And you must use the buttons on the unit, NOT on the remote, to enter the service menu. Once in the menu, use your remote to select the auto calibration menu and go from there.
2. This will fix the C 13:00 problem on any Sony DVD player.
With the machine turned off on standby, press the following 3 buttons
on the handset, in order: TITLE CLEAR POWER. The Diagnostic Start menu will come up on the TV. Select the appropriate button number for "auto adjust". The
machine basically does it all. It asks you to select either a single
layer or double layer disc (whatever your offending disc is.) Ejects
the tray, asks you to put your disc in and then calibrates it. (It's
over in about half a second... painless) Just follow the prompts on the screen
Posted on Oct 30, 2007
  • David Griffin
    David Griffin Nov 23, 2013
    Even when I start with the Single Layer Auto Adjustment, it stops after 3-4 sec saying "Error!!! Adjustment Quit_ Focus On"
How can I get my RCA 5 disc CD changer stereo to work right?
I have an RCA 5 Disc Changer, purchased at Target. The first one had a prolific issue of skipping on discs. It would play part of song on the first disc then suddenly change to the next disc. However, it did not ALWAYS do this, just sometimes, seemingly at random. Then one day, it would suddenly work just fine on all 5 discs. Eventually it simply would not play an entire song at all, so I took it back (within the time of the warranty). They had 1 of the same left on the back shelves so was able to get that one. This one started doing the exact same thing within the month. Now, it will not READ discs. It will simply read, 'Read"..and then when it comes up showing the disc number it has all zeros. I tried skipping to the next disc and then the next, and suddenly it read. That was fine for two days, then it would not even do that. I tried using compressed air inside all of the open disc drawer, and on all the discs but to no avail. Just now I tried tilting the entire unit Back at about a 30 degree angle and while in that position hit the 'disc change' button on the remote and suddenly it read. How long will this work? Have no idea. Very irritating - and it's hard to find this kind of player anymore, apart from a Component System which is a whole new playing field. Amazingly , I had bought my first changer, a 6 CD changer, cheap one at wal mart long ago and it lasted me about 10 years and never had a problem. It was a no-name brand too, I would expect better from RCA but alas, tis not the case.
Jun 05, 2014 | RCA Audio Players & Recorders
Panasonic bluray SC-BT207 won't read disc
Depending upon the age of the equipment and the fact that a laser cleaning disc was used the drive may be failing and only able to read a disc intermittently..
Jan 09, 2014 | Panasonic Audio Players & Recorders
After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
the dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
Nov 17, 2009 | Mintek DTV-263 26 in. LCD Television
CD player will cycle through all 5 discs and then show "No Disc"
HI. the main board is ok. this is the actions of a malfunctioning optical lens assembly. the lens is unable to read, due to the damage to its structure or, the laser has burned out.
The main board is programed to issue the (no disk) alert if the lens doesn't relay audio data. simply replacing the failed optical lens assembly will fix this issue.
Jun 17, 2009 | JVC XL-F254BK 5-Disc CD Changer
Game randomly quits, disc doesn't read
buy a new layser i did it i think if you want a high tek layser get hggh25 layser
May 04, 2009 | Sega Dreamcast Console
Dvd disc not playing
Buy a cleaning disc for about $15.00. If that doesn't work it's time to buy a new one.
Mar 16, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Random unreadable disc errors
I had the same problem but i sent it in. They said it was the eye reader error. Or the thing that reads the disc. Try buying a brand new game and try playing it. Alot of times when i have disc read errors i put the disc in where the xbox 360 part at the top goes in facing the xbox. Try that to see if it helps.
Mar 15, 2009 | Microsoft Xbox 360 Console
CD player won't play random
the most likely problem is a weak or failing optical pickup. try a cleaning disc first there may be dust on the lens. do not use any liquid to clean the lens. remember this is an optical system if it can't focus properly or "see well" it can't read.
Feb 03, 2008 | Audio Players & Recorders
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
Sony DAV-S300 System Logo
1,375 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
