Question about Acer AL2017 20" LCD Monitor
Shutting off After 2-3 hours functioning, screen becomes black, the front panel led remaining green and after a few couples of ON/OFF from the power switch, the monitor SHUTS DOWN AND REMAINS SO. I have to pull the power cable and it will start again only after 15-30 minutes. It is not related to room temperature.
  • bonifaciu Aug 18, 2007
    I agree, the problem is that I have to wait at least 2 weeks and to pay the transport of the package Montreal-Toronto-Montreal (Acer closest repair center), though is under the warranty. It should cost me ~25 USD AND i'm not happy with that...
  • 63 Answers
It may not be related to room temp, but it sure sounds like there is an internal problem relating to temp. Meaning, there is a component (probably a capacitor) getting over heated or leaking. If this is still covered under the mfg warranty, I would contact them to get it fixed. If not, then taking it to a repair facility that can repair it is probably a good idea.
Posted on Aug 18, 2007
  • Craig Nelson Aug 18, 2007
    I had the same issue with BenQ. But it beat spending $100+ on a new monitor and I had my laptop as a backup. I feel your pain.
New power supply board and screen goes black
It sounds that the off timer has been set to one hour. Check it.
May 29, 2013 | Philips 47PFL3704D 47 in. LCD TV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Dec 22, 2008 | Vizio L32 32 in. LCD HDTV
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Acer AL2017 20" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
