Question about Sylvania 6620LDG 20 in. EDTV-Ready LCD TV/DVD Combo
What the heck
The screen has circle in each corner and a line across the center. i don't know what's going on with this tv
LN46B610A5FXZA Gray Horizontal across full Screen with color vertical lines in lt corner and center of screen
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 26, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
Screen has bright circle in center and dark around edges and corners
You may want to remove back cover and wipe/clean the three large black lens.
Also go to an unused video input and examine screen; Same problem?
Let me know what you find.
Steve
Feb 29, 2012 | Sony KP-61S65 61" Rear Projection...
Black circle and vertical lines in 42LG5000 LCD TV
What board did you change?...the Tcon?
Mar 04, 2018 | Televison & Video
Display has black circles lower left corner and upper right corner. were smaller but have grown. Maybe 2 in. each now. Also lines in pink and black across bottom. Everything else works OK. Bought past...
Well your on the right track I would say it's your LCD because your video chip wouldn't make black circles I don't think. The pink and black lines are a symptom of a LCD that has been broken and the circles sound like someone squeezed it to pick it up by the screen maybe. That would be for your venders warranty department to figure out though. If you really want to know you could buy a cable to hoot it up to an external video source if the display is fine, it's defiantly your LCD.
Jul 29, 2011 | Dell Computers & Internet
Thin white line across center of screen Fisher PC-32S90
yes there's a lose connection of your tv. It needs to re solder.if you know how to solder .,solder the vertical section specially the vertical I but be careful of short circuite coz it may damage your tv set.
Nov 16, 2008 | Fisher PC-32S90 TV
Big black circle and lines across my screen
I,m sending the monitor to emachines repair center.
Jul 26, 2008 | E-Machines eMachines Monitor E15T4
Line across top of screen
The line is actually part of an unseen border.
Jul 02, 2008 | Sega Genesis Console
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Blue circle across top of tv screen & maybe some yellow
Good Day,
Does the blue spot have tin white lines?? Is there a picture behind the 'circle'? You may a blue crt (tube) problem.
Jun 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sylvania 6620LDG 20 in. EDTV-Ready LCD TV/DVD Combo Logo
49 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
