Question about Mpio FG200 MP3 Player
MPIO MP3 HD300
When I turn on the MP3 player it just has the MPIO logo screen and doesn't progress any further to the menu. I can't listen to music and my pc doesn't recognise it anymore when I plug it into the USB port. I have a sneaky suspicion that I may have lost some of the files that were on it when it first came to me.
  • 20 Answers
This should do it This will do the trick http://www.mympio.com/index.php?topic=13.0
Posted on Sep 04, 2007
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Feb 29, 2008 | Mpio HD-300 MP3 Player
Mpio hd300 mp3 player wont turn on
my ******* zen vplus is not turn on at all i reset and it still not work
Apr 17, 2008 | Audio Players & Recorders
BRAND NEW MPIO HD300 Completely DOA!
It's a reasonably straightforward task. There are 2 screws at either side (near the top) of the player. You'll need a small Alan-key to remove these. Once this is done, carefully prise off the back cover and you'll be able to see the battery - at the back. Just un-clip the battery cable. - You might want to check the connection in the first instance, if however, the battery needs replacing see replacment battery model number below: -
UP325385A4H-UP325385A5H
Hope this heps
Nam1
Feb 21, 2008 | Mpio HD-300 MP3 Player
Frozen - Mpio HD-300 MP3 Player Problem
Sounds like the player can't see it's hard drive, not much you can do if the drive is dead. If it's under warranty then have it fixed.
Jan 18, 2008 | Mpio HD-300 MP3 Player
Try to reformat using your USB 2.O, with The Super-Reboot MP3 Software, may take up to 24/48 Hours to Reformat
MPIO HD 300 Freezes/Computer won't recognize
1. there is a reset button if the player is stuck, there is a hole on the front panel use a paper clip.
2. Hard Drive probably got disconnected from the FPC cable, you might need to open the player to fix this issue
Dec 10, 2007 | Mpio HD-300 MP3 Player
MP3 player something wrong
Hi Samusv2,
Try removing the battery completely for about 1 minute, then put it back in then try to see if doe shte same thing. Insert another comment on this post and I will respond.  Cross your fingers.
Oct 13, 2007 | GoVideo Rave-MP ARC5.0 MP3 Player
Won't turn on
either you got a faulty surface mount regulator IC or you got a corrupted flash memory. Try pressing play button, then alternately press volume down (-) and Rewind (<<) buttons. When the "FORMAT? Press Menu" appears, press MENU BUTTON. A LOW LEVEL FORMAT will be in progress. When it's done, reload firmware recovery using MPIO Utility. If however you nothing appears on the screen afteryou pushed the play, rewind, and minus buttons,or still it doesn't power up, you've got a faulty regulator IC. It is the five pin chip colored black with the markings "PHK" (use a magnifying lens to confirm) located on the left besides the battery connector (facing up, with the earphone jack on the top). If you had micro soldering skills, then you can remove the chip and replace, if you can find a replacement...
Apr 03, 2007 | Mpio FL300 MP3 Player
Frozen screen/ can't turn it off
Try the reset button which is pin-sized hole on bottom right when looking at the HD-400. You will need paper-clip to press it.
Jan 16, 2007 | Mpio HD-400 MP3 Player
Mpio FG200 MP3 Player Logo
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
