Question about Lexmark C500n Laser Printer
Lexmark C510 When i am printing some graphics are wiped out (easy to erased by hands) Please help!!
  • Moe AA Aug 20, 2007
    How can I adjust the fuser temperature?
    Thanks,
    Moe
    Scholar:
  • 31 Answers
Any time toner comes off the page it means that it's not being "fused" to the page by the hot rollers in the back. You may need to adjust your fuser temp. settings, or replace the fuser itself.
Posted on Aug 20, 2007
  • David Washer
    David Washer Aug 21, 2007
    Hey Moe,
    When I wrote at first I mixed up your printer with another that I had worked on recently. The idea is still right, but the adjustment can't be made in the fuser temp. However, you might want to try the following:
    1 Driver media settings Driver media setting is wrong. Ensure
    proper media setting is selected for
    specific media in use.
    2 Nonrecommended paper Nonrecommended paper is being
    used. Replace paper with
    recommended.
    3. If those don't work I would highly recommend replacing the fuser.
SOURCE:
Lexmark C510 can not print and display with 994 service engine error. How to solve this problem. Thank you very much
Please click on the link http://bit.ly/rv412w to see instruction on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Jun 08, 2011 | Lexmark C510 Laser Printer
Lexmark C510
First try it and then see any problem is coming or not
Aug 18, 2008 | Lexmark C510 Laser Printer
My Lexmark C510 keeps popping up with a Paper Jam 241 error in Tray 1. There is no paper jam. I open the printer door take the tray out, put it back in and shut the door. How can I fix this problem? I...
I have a Lexmark C510 colour printer: Manufacture date June 2005.
I had been getting the "Paper Jam 241 error in Tray 1" message for some time. Sometimes it would print just fine but in the past several months, it's been bad. I'd pull the tray out (notice roller marks on the top sheet that was only partially fed), reinserted the sheet properly into the tray and try again and again. The techy at Lexmark mentioned that I could purchase a new rubber roller that feeds the sheet but that I might first wipe down the roller myself as they get worn and old. I first wiped it down with a damp cloth to clean it then thought to try reconditioning it with leather conditioner we'd purchased for our couch (I'm sure Amourall would work just as well). Voila, the old, dry roller was picking up paper again. Just open the rear door and that grey roller (it's black again when you recondition it) is at the bottom. Hope that helps.
May 11, 2010 | Lexmark C510 Laser Printer
Lexmark C510 printer doesn't print yellow color.
Try the old one again. If this works you have a defective new catridge. This sometimes happens.
Feb 20, 2010 | Lexmark C510 Laser Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
How do I clear the memory for the Lexmark c510 printer when I receive a memory full warning?
This is from the service manual, unfortunately there isn't a cold reset, you can perform an EP factory reset in the diagnostic mode, but this won't cure your problem. Investing in some more memory is the best answer
Press Go to clear message
and continue printing job. Job
may not print correctly.
Press Menu to open Job Menu
and cancel current job.
To avoid this error in future:
• Simplify print job by
reducing amount of text or
graphics on a page and
deleting unnecessary
downloaded fonts or
macros.
• Install additional printer
memory.
Apr 15, 2009 | Lexmark C510 Laser Printer
Only printing test sheets
your printers drivers did not works properly please install the correct driver on your system and after the probelm will continue
please chek the cable
Mar 12, 2008 | Lexmark C510 Laser Printer
Lexmark C510 printing problem
goto menu "1" -- find black and white lock and set to off. I almost threw out a printer that was given to me because of a menu setting.
Feb 22, 2008 | Lexmark C510 Laser Printer
i want to driver lexmark printer c510
Feb 22, 2008 | Lexmark C510n Laser Printer
Lexmark C500n Laser Printer Logo
78 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
