Question about Nokia 7373 Cellular Phone
Change to another colour casing
How do you remove the old fascia?
    Sergeant:
  • 452 Answers
Just open the body cover of ur handset and clean it up.+
2. if u r not able to do that then send ur phone to service centre for service.
Posted on Oct 18, 2007
SOURCE:
Remove back bumper from 2004 jeep grand cherokee
  • Raise and support vehicle.
  • Remove wheels.
  • Remove plastic push pins attaching fascia to fuel tank skid plate.
  • Remove plastic rivets attaching fascia to wheel liner.
  • Remove nuts attaching upper edge of fascia to quarter panel and wheel liner
  • Remove plastic push pins attaching fascia to liftgate opening
  • Remove screws attaching fascia to liftgate opening.
  • Remove D pillar trim and scuff plate outboard screws.
  • Remove the rearward tie down screws and the aperture trim panel.
  • Carefully peel back the rubber body sealer patch to access the retainer clips.
  • Release the forward and rearward retainer clips on both sides of the fascia.
  • Grasp forward edges of fascia and pull outward to disengage retainers attaching fascia to quarter panel
  • Separate fascia from vehicle
  • Jul 06, 2017 | Jeep Cars & Trucks
    Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
    You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
    Mar 13, 2014 | Bosch Dishwashers
    How do I replace my rear bumper on my 04 pacifica
    1. Open liftgate.
    133387935 Fig. 12
    1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
    2. Hoist and support vehicle with safety stands, as necessary.
    133387936 Fig. 13
    1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
    2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
    3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
    4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
    5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
    6. Place fascia on a clean surface.
    133387937 Fig. 14
    1. Remove park assist sensors, if necessary (Fig. 14).
    133387938 Fig. 15
    1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
    2. Using a trim stick release locking tabs and separate the upper and lower fascia.
    133387939 Fig. 16
    133387940 Fig. 17
    1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
    2. Remove molding from fascia.
    INSTALLATION
    1. Place bright chrome molding in position on the upper fascia.
    Jan 06, 2012 | 2004 Chrysler Pacifica
    How to remove the rear bumper cover on a pontiac 2004 grand prix
    1. Open the trunk.
    2. Remove the rear compartment sill plate. (Trim round the back edge of the trunk)
    3. Pull the left and right compartment side trim panels down to access the fascia bolts and nuts.
    4. Remove the tail lamps.
    5. Remove the fascia bolts and nuts from the rear bumper fascia 1 nut 1 bolt on each side near tail lights.
    6. Remove the push-in retainers from the top edge of the fascia.(4 plastic circles, pull up on center of cirle with screwdriver
    7. Raise and support the vehicle.
    8. From underneath Remove the push-in retainers from the rear bumper fascia (one on each side I think)
    9. Remove the fascia bolts from the rear bumper fascia. on on each side from, up where the facia connects to the quater panel)
    10. Remove the rear bumper fascia from the vehicle
    Apr 14, 2011 | 2004 Pontiac Grand Prix
    I WANT TO CHANGE MY Housing Fascia Case Faceplate For Nokia E65 with keypad
    Well you need to buy a faceplate or fascia for your Nokia E65. I receommend ebay. Looks like they are about 10 dollars for the set.
    Check out the following link for a guide video guide and links showing what is available on ebay.
    Change Faceplate on Nokia E65
    Jan 20, 2010 | Nokia e65 Cellular Phone
    Replacing front fascia on samsung sgh g600
    The front fascia is part of the LCD screen you will have to get hold of a complete screen for the colour of your phone.
    When taking the phone to pieces the part most people forget is the screws behind the logo and the bottom ribbed cover.
    Also underneath the phone there are two screws to remove the reset are easy to find I suggest that you use a magnetic dish as the screws are very tiny and easy too loose, and hard to find replacements.
    Hope this helps please rate !!!
    Oct 20, 2009 | Samsung Cell Phones
    Trying to change the front passenger turn light
    Cornering Lamp Removal & Installation To Remove:
    1. Remove the bulb socket from the cornering lamp.
    2. Release the cornering lamp forward retaining tab and pull the front of the lamp away from the fascia.
    3. Remove the cornering lamp rearward retaining stem from the fascia by pulling the lamp forward.
    To Install:
    1. Place the cornering lamp rearward retaining stem into the slot in the fascia.
    2. Engage the cornering lamp forward retaining tab into the fascia by pushing in on the front of the lamp.
    3. Install the bulb socket into the cornering lamp.
    Jul 10, 2009 | 2004 Chevrolet TrailBlazer
    Change headlight
    hello. below is the procedure for removal of the headlamp for bulb replacement. to access the headlamp you will need to remove the bumper fascia. http://gsi.xw.gm.com/image_en_us/gif/000/001/725/1725371.gif Callout Component Name 1 Front Compartment Sight Shield Plastic Retainers (Qty: 6) 2 Front Compartment Sight Shields (Qty: 3) Tip Each front compartment sight shield is serviced separately as needed for repairs http://gsi.xw.gm.com/image_en_us/gif/000/001/728/1728611.gif Callout Component Name Preliminary Procedure Remove the front wheelhouse liner. Refer to Front Wheelhouse Liner Replacement . 1 Front Fascia Extension Plastic Retainers (Qty: 5) 2 Front Fascia Extension http://gsi.xw.gm.com/image_en_us/gif/000/001/733/1733942.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedures Remove the front compartment sight shields. Remove both front bumper fascia extensions. 1 Front Bumper Fascia Reinforcement Nut (Qty: 2) Tighten 6 N·m (53 lb in) 2 Front Bumper Fascia http://gsi.xw.gm.com/image_en_us/gif/000/001/736/1736893.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedure Remove the front bumper fascia. 1 Headlamp Nut (Qty: 1) Tighten 6 N·m (53 lb in) 2 Headlamp Bolts (Qty: 3) Tighten 6 N·m (53 lb in) 3 Headlamp Assembly
    Jun 13, 2009 | 2003 Cadillac CTS
    How do you replace headlamp bulbs on 1999 chrysler 300
    You half to remove the Headlamp housing to change it. Here is the instructions out of the factory manual.
    Tell me if this works for you?
    HEADLAMP HOUSING - CONCORDE/LHS/330M Headlamp lens fogging is a normal condition and does not require service unless excessive or continual. Moisture will vent from tubes or vents located on the back of the lamp.
    REMOVAL
    1. Release hood latch and open hood.
    2. Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners Access Rubber Grommet
    3. Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield Fastener Locations
    4. Remove the push pins attaching the fascia to the upper radiator closure panel Remove Push In Fasteners
    5. Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s) Headlamp Jackscrews
    6. Roll fascia forward to clear way for headlamp housing removal Roll Fascia Forward
    7. Disconnect wire connector from back of lamp socket(s) and/or bulbs.
    8. Remove headlamp housing Remove Headlamp Housing
    INSTALLATION CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
    1. Place headlamp housing into position.
    2. Connect wire connector to lamp socket(s) and/or bulbs.
    3. Verify headlamp and signal lamp operation.
    4. Install jackscrews to attach headlamp housing to crossmember.
    5. Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
    6. Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
    7. Install nut on fascia stud through the splash shield access hole.
    8. Verify headlamp operation and alignment
    Mar 27, 2009 | 1999 Chrysler 300M
    7373 fascia
    well, this phone sint made to change the fascia, in english, you cant change the fascia like a 6230 etc, BUT never fear!!, just type in ebay "7373 fascia" and someone may give you a housing for it, this will require you to unscrew the phone and do it manually, so i suggest you watch out, but everybody learns the hard way!
    hope this helps!
    Dec 08, 2007 | Nokia 7373 Cellular Phone
    Nokia 7373 Cellular Phone Logo
    Top Nokia Cell Phones Experts
    jonathan mariano
    jonathan mariano
    Ekse
