Question about Panasonic Viera TH-42PZ85U 42 in. Plasma TV
Tv wont turn on, red light blinks
The tv shut off by itself last night and now the red light, hte power indicator light, just blinks about ten times, stops for a few seconds and then blinks again.
  • Anonymous Apr 15, 2009
    throw the TV in garbage...
  • Anonymous Mar 19, 2014
    INSTALLING NEW RECEIVER AND NOW THE TV WONT TURN ON. NO RED INDICATOR LIGHT AT ALL
    Problem Solver:
  • 11 Answers
I have the same problem
Posted on Apr 14, 2010
SOURCE:
Why wont the tv wont turn on. It blinks ten times than stops and starts again
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices...
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 24, 2016 | Televison & Video
72" Sony shut off in me last night and won't turn back on. It's about 7 years old.
what is the model of your tv, then does any power indicator at the front or blinking light? then can you tell me how many times does it blinks thanks.
Oct 23, 2012 | Televison & Video
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
WHEN TV IS TURNED ON IT IMMEDIATELY SHUTS ITSELF OFF. THERE IS A RED LIGHT FLASHING IN THE FRONT RIGHT CORNER BOTTON
The light is hte standby light and it should be blinking a repeating count. That count will indicate the defective circuit. Please post the count and confirm your model to be KV-27HS420 and we can look up the code and provide the probable repair solution.
Thanks,
Dan
Mar 02, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Mar 11, 2017 | Samsung Televison & Video
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sony tv wont start up???
The flashing should be a repeated number of blinks. Please post that count as that will indicate the circuit in which the set detected a problem. The set is in protective shutdown. Using hte blink count, we can determine the possible problem and solutions.
Dan
Jun 18, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Jan 08, 2008 | Panasonic Televison & Video
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
2,686 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
