Question about Whirlpool S20DRSS33 Side by Side Refrigerator
Water running down door & dispenser light always on......
Hello, my 2 year old whirlpool 'American frige' is leaking water from behind the unit on the door (not the tray). It is running down the front of the door. There isn't a lot of water but it's enough to leave an unsightly streaking on the door & a wet floor. Also got a problem with the dispenser light staying on, I've had to take the bulb out as it was heating up?? Help please. Thanks
  • 87 Answers
If you trace up from the water leak it must have an origin. If it starts high level I would suspect the door not sealing allowing warm air to be chilled down cold enough to condense. If it starts around the water or ice dispenser you may have a bed connection or break in the supply lines. I am assuming this is on the freezer section. It would also account for the light as there are normally door switches for the light and fan. If you open the door on the freezer section and push on the switches you should see the light go on and off. Hope this helps, water leaks are always a pain even for engineers.
Posted on Aug 17, 2007
Hello,have a whirlpool gs6nbexrb01,side by do I remove the dispenser touch panel unit in freezer door, thanks
Heat from the night light probably has cracked the delivery tube for the water dispenser. There are repair kits available. from Whirpool. Instructions are included
Sep 29, 2016 | Whirlpool Refrigerators
Hello Heatman101....I have a 2-3 year old Whirlpool frige,bottom freezer.The humidity in the past month around Ottawa Canada has been extreme.It seems on these days water is leaking on my hardwood oak...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
If you need more help GO HERE:
Thanks for using fixya
Leo Ponder
Aug 24, 2011 | Whirlpool Refrigerators
Water is accumulating and freezing on the bottom of the freezer
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leak in the drainage pan under frige
1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
Check out this link, its a video shows you how to fix a leaking fridge.
Apr 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Water dispenser not working on my whirlpool american fridge freezer ? Changed filter a week ago, is switched on but no water coming out of dispenser?
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad. If that is not it than there is a switch problem at the door.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool American Fridge Freezer
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Whirlpool S20DRSS33 Side by Side Refrigerator Logo
135 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
