Question about Philips Magnavox MWR10D6 DVD Recorder
Timer Recorder I can not get the timer recorder to work.
  • Anonymous Feb 23, 2008
    MAGNAVOX DVD RECORDER MODEL # MWR10D6: Is a piece of junk. Yet another worthless waste material and rescources. In other words they or someone else could have taken the materials and energy used to assymble this thing and used it for some other appliance or device that would actually work. This thing is so worthless that it was environmentally irresponsible for the manufactures to even make it. Now all it's good for is filling landfills.
    My suggestion is to do as I am right now and go onto any and every forum, or message board you know about and warn as many people as you can away from this piece of junk and the SCAM that is being perpatrated by Magnavox and whoever else helped them cook up this scam.
    I've even made space for a photo of it and description of how sorry it works on both my myspace.com and facebook.com pages.
  • nyscouse Mar 22, 2008
    this unit does not timer record but will record if you hit the record button, which is no good if you are away, and on the rare occasion that it does record via the timer it will record the first one only then turn off the unit, and when you turn it back on it is as if you just connected it for the first time. It worked fine for the first few months can any one help?
    Problem Solver:
  • 9 Answers
Posted on Feb 23, 2008
SOURCE:
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Jan 17, 2009 | LG Corbel A- Accessory Range Hood
Timer recorder n/w
the recorder must be off, otherwise timed recording doesn't work
Aug 29, 2008 | LG RH177 DVD Recorder/HDD Recorder
Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
Jul 24, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Samsung dvd sh873 recorder with hard drive. we are having problems recording tv programmes with the timer. we can record instantly. we are following the manual but it is not very clear. can anyone give...
Buy another type of recorder - we are already on our third replacement Samsung SH873 - all faulty and different faults on each. Load of rubbish - won't waste my money again on a Samsung recorder.
Jul 08, 2008 | Televison & Video
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Timer record set
Make sure the clock is set. Since the clock must be set before the timer will work, be sure you have entered an accurate date, day of the week, and time (including AM or PM). And always check the clock after a power outage. Also, check that your videotape does not have the tab removed which protects against further recording.
Mar 08, 2007 | Zenith TVBR1322 13 in. Combo
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
