Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Tape Stuck I was inserting a VCR Tape in this Recorder/VCR to copy to DVD. It did not fully insert ... instead error message "F06" appeared, and I was unable to do anything else, including ejecting the VCR. I don't know if there is a release pinhole or anything else on the model to free the tape. The manual covered nothing with this error message. How do I eject the tape and have the recorder work once again?
  • Anonymous Mar 16, 2014
    No more details to add
    Dear Sir/Madam: I have had an LG DVD & VCR (model: LVC-837) for under two years and have used it successfully for most of that the time. (I have used other VCR's for thirty years and have never had trouble with timer recordings - even though each brand of VCR has slightly different ways of inputting instructions). During the last couple of months I have encountered a problem with timer recording on my current LG VCR that I cannot understand or correct. When I set the VCR timer recording for several programs the VCR appears to record one or two programs as per instructions (date, start and end time, channel, speed, etc) inputted. Then, without any explanation, the VCR ejects the tape and the remaining programs inputted as timer recordings are left unrecorded. I am always careful to rewind tapes to zero before inserting into VCR, I check and double-check all the input instructions data, etc. But after correctly recording one or two complete programs as per input instructions the tape is ejected and none of the other programs are recorded. Your assistance in correcting this problem would be greatly appreciated. Marvin Blauer ===================
    Scholar:
  • 76 Answers
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
RCA DVD/VCR model DRC8320
Interface error
(and or)
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
How can I record from the vcr to the dvd
on a combo unit ,insert the vcr tape and then put a blank dvd r /rw in to unit , you should then press rec button and records to dvd.
note you cant copy proteceted tapes due to the macrovision
Mar 25, 2008 | Daewoo DVRS04 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
VCR Tape Stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
VCR Tape Stuck
my tape got stuck too, i opened the bottom, then located the mechanism that started the eject program. After turning some wheels the eject automatically started. Try that...
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
225 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
