Samsung Galaxy Tab Tablet PC Logo
Anonymous Posted on Jun 01, 2013
Camera failed Every time I want to talk pictures on the front sreen of my camera says warning the camera failed and even when I go into applicantion on my samsung and go to camera it says camera is disable
Anonymous
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Jun 02, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
66
Questions
Helped
7152
Points
148
Have you recently messed with your tablet? I recommend doing a factory reset and contacting Samsung about your problem. It is probably just a software problem. You can also check for software updates in the setting section.
Hello, I have a Samsung Galaxy Tab A. The camera suddenly stopped working with a pop up: "Warning. Server error occured. Restart camera." Only option to continue is "OK" . Please help!
First try restarting the tablet.
Then try logging out of your Samsung account and logging in again.
If that doesn't work, try installing a different camera app from the Play Store (Open Camera is pretty good).
1helpful
I can barley hear my dragon 10.1 even at full volume
If you are talking about speaker volume, not earphone volume, chances are you have a defective speaker assembly unit which must be replaced.
Access picture sent to my phone?
For everything you want to view on a computer, tablet or phone, you need a viewer. For pictures in .jpg go .png, you need a Photo viewer. Dow a .PDF, you need a PDF reader and for text you need a text reader. Formatted text, need a word or other reader.
So downloading is not the biggest problem. Having the correct programs (apps) installed is more of an issue.
Check for your device what you need to view the picture. Realise most RAW pictures can't be viewed on phones or tablets, because every camera model has its own RAW format and needs its own translation. For RAW you need even special program's on a computer.
First make sure you can view the file on your tablet, before you start downloading it.
My asus tablet wont sense the integrated camera, i have taken pictures off it before, but now it just doesnt sense it, even after ive refreshed the whole system
Have you rebooted or done a hard reset since the update?
"Cold Boot (aka Hard Reset)
Unplug the power cord and shut the unit off. Press and hold the VOL DOWN and then POWER button at the same time for at least 10-12 seconds until after the start-up screen appears and is joined by some small print at the top of the screen then let them both go. If the TF booted the way it always does, you have not accomplished the task,try again until you have seen the 2 icons in the screen.
After a few seconds you should see a couple of shapes in the middle of the screen called "Wipe Data" and "Android". The right "Android" will have a green highlight fading in and out. Wait a few more seconds until the term "Cold Booting Linux" appears in the list near the top of the screens and let it reboot. If you own a keyboard dock be sure you do this with the dock connected.
2answers
Putting dates on pictures
download the camera time and date stamp app from android market if it is compatible with your device
Samsung galaxy 2 tablet 10.1 camera failed
OK, here is the issue with the "camera failed" - the PHYSICAL part of the camera is fine, it is the SOFTWARE that is flawed. Until Samsung to fix this issue downloading a 3rd part camera software program will allow you to at least use the camera. As of 4.0.4 the issue STILL exists. Samsung support is of NO HELP. How do I know this I have a 7.0 Tab myself and spend lots of time in the forums AND I have the exact same problem.
All these do gooders telling you to take this thing back for a new one are wasting your time, you WILL have the same issue with another new unit. Either return it and get your money back or wait a bit for the fix to come in an update. No cleaning the lens will not fix the gray pictures either.
Good luck
5helpful
I just bought Samsung Galaxy Tab GT-P100 last month, but now somehow Camera feature is not working. There's message says: "Warning: Camera failed" pops up on screen whenever I want to use camera...
do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
2answers
My kindle is stuck on a page. It won't change
Are you sure the Kindle powers up? It may show something on the sreen, even if it is not turned on (e-ink screen does not need a powersupply to show an image). Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
