Question about Toshiba MV20P2 20" TV/VCR Combo
Television last two year i didnt use my television ,now am trying to switch on it does nt works .the tecnician replace the main bord with thoshiba bord ,now it showing red,green colours at the four corner of the screen what is this?can you pls help me to solve this problem
    Novelist:
    Champion:
  • 275 Answers
What you are describing is a Degaussing Problem. This normally occurs if some Magnetic source - speakers, Tape recorder, Walkie Talkie, etc- is brought close to the TV. If this problem has started imediately after the technician replaced your Main Board, it is entirely possible that he has forgotten to connect the Auto Degaussing Coils to the Main Board.Call him and ask him to do so. he will also be having a small device called a Degaussing coil, which he should bring and 'demagnetize' the Picture Tube. should not take more than 10 minutes. If it has started after a few days of the Main board being replaced, then, do not worry, they will go away on their own in a few says, when the Set's Automatic Deagaussing circuits will slowly clear the patches. Also, try to see and locate the source of Magnetism - listed above - and remove from the area around the TV set. Again, the technecian can bring his Deagaussing Coil and demagnetize the Tube, and picture should now be Ok.
Posted on Aug 18, 2007
SOURCE:
My Proview RX-326 lcd tv Has sound & picture but Picture mix colers brite
There is some incompatibility issue. Did you check the format is set correctly for PAL/SECAM etc.?
Jul 28, 2012 | Proview PA-32JK1A 32 in. LCD Television
The buttons on the tv wont work nor will the remote
MAIN BOARD IS MALFUNCTIONING...2 DIFFERENT MAIN BOARDS FOR THIS TV...IF S/N STARTS WITH W2702...USE P/N 5600110351...IF S/N STARTS WITH W2751...USE P/N 5600110493...PART CAN BE ORDERED FROM ANDREWS ELECTRONICS IN CALIFORNIA..IF YOU DO NOT HAVE THE EXPERTISE TO REPLACE BOARD..THE TV SHOULD BE TAKEN TO LOCAL SHOP...HOWEVER..USUALLY PARTS ARE WARRANTED FOR 1 YEAR..CHECK YOUR RECEIPT.
Jun 03, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Flashing
i would get in back dust it all out cheak fans ok maby add fan in on it to help heat go down main bord hairline cracks that will cuse your issue have to solder back in or get new main bord ok cuse of power heat kills these tvs
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
LED LIGHT FLASHES 12 TIMES. 12V PROBLEM?
i,m have the same probolem i check voltaje and disconect the left power bord (HDB4-main) and the green led stay on them check pcbord an find diode in chort , chenge but continue the same problen i thing the big ic in this bord is bad but need more informaton for check more and/or buy parts for repair this bord or replacment.
Dec 15, 2007 | Sanyo DP42746 42 in. Plasma Television
Hel whit mi hitachi
Remove speaker grill cover on tv lower front.Remove access panel.
Locate small blue push switch = activate convergence grid,then
use 2 & 8 , 4 & 6 , and enter along with adjuster arrows if I
remember right, then magic focus last..............T.
Nov 10, 2007 | Hitachi 43UWX10B 43" Rear Projection...
I NEED SOLUTION
Hi, Pls check the small Fuse for the supply of the fan. Or you can send it to us to repair.
May 26, 2007 | Toshiba TLP T50MU Multimedia Projector
Toshiba MV20P2 20" TV/VCR Combo Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
