Question about Protron PLTV-32 Television
Girociclo I'll pay to have my ac adaptor fixed!!!!!1
I have the old one...took it to electrical shop but it was beyond their competance....can you help me???? I'm in Virginia at 703 303 1185 is my cell phone...Protron is worthless as they will never have the part!
  • 1 more comment
  • jim allegretto Aug 21, 2007
    I don't know how the hell that helps..
  • jim allegretto Oct 09, 2007
    Protron has now run out of adaptors...after I sent in my check...they apparently had a 'teaser' supply (my guess is 1 or none). They are the worst logistical and support company in the industry. At one time they were considered reputable in tawaiin. Now most tawaiinese know protron/spectronics is synomous with poor support and customer service. The California attorney general really should investigate this company. Please feel free to file a complaint as I did.
  • Anonymous Apr 07, 2008
    contacted customer service numerous times. given the runaround with many excuses why the part was not forthcoming. they do not have the part and cannot get it. they have my check but I have no part.
Hi all.  As the rest of you, the power adapater to my Protron (same model above) gave out, and as indicated in this and other blogs on this site, was told by the company to call back in a few weeks when they "should" have more in stock.
While it's a bit more pricey, I found a company by going on e-bay "lcdpayless" by typing in the model No. of the adapter.  They make an "equivalent," listed as 99% favorable reviews, that is better and should last longer.  Best thing, it shipped within 24 hours.  If you are like me and don't care to wait months before Protron (they don't take orders) may have one or two more in stock, give it a shot!
Posted on Oct 30, 2007
  • STANGRIDER58 Nov 03, 2007
    More from STANGRIDER 58 (Best Solution). By the way, I received my "equivalent" from lcdpayless within 3 days. As a follow up, it works like a charm! The box will appear slightly different as they have separated elements into 2. The only difference is that you need 2 outlets. All systems are go, and my Protron PLTV-32 now works perfectly. Give it a shot.
Hi, has anyone actually received the ac adapter, I have called everyday for almost 3 wks, I called again today, and was told they received ac adapters, but it was not for the pltv32, I am now going to try and have the adapter fixed, has anyone tried that? and if so did it work?  I guess I should feel blessed, I have had the tv almost 3 years without any problem, but I can not see throwing out a tv when it works fine with the exception of 1 ill made external part. tina
Posted on Oct 25, 2007
The phone # is 888-257-8899
Posted on Oct 08, 2007
Call protron..they now have the adaptor for 79.99 be prepared to send them a check and wait another 2-3 weeks! A normal company would accept VISA and fed express the part out....
Posted on Sep 21, 2007
Are you still searching for the AC Adaptor? Do you have a phone number where I can order this AC Adaptor from Protro? My 32inch Protron LCD won't come on and I have a strong feeting it is the AC Adaptor. I also took it to a tech but he was unable to fix it.
Protron said that I would have a new adapter(090-02180-13) in 2 weeks. My tv was under warranty but if it wouldn't have been they said you could order an adapter for $79.00. My adapter is over heating and I have placed a small fan blowing into it and so far it has kept it cool and the tv has not shut off automatically as of yet.
Posted on Sep 18, 2007
Could you list any (probably) keyboard internal problems that would cause the fuse in the adaptor to blow, in a PC88MX (yes it's 20 years old *L*). The original fuse blew a couple of weeks ago, after
The unit uses a 9.5V AC (at 2A) 'step down' transformer, its doubtful you will be able to replace it with anything modern (as most things are DC, not AC nowadays).
However, you may be lucky and find a similar one in a junk shop or flea market type place, anything in the range 9 - 10V AC and NOT DC should be fine, as long as its at LEAST 2A (or 2000mA), not below, although something at 1.8A might work.
Just splice the leads (doesn't matter which way as its AC) onto the old plug from the damaged unit, just make sure the leads stay apart!
Any decent electrical engineer or advanced electrician should be able to do this (properly!) or fix the unit.
That's the simplest fix.
Splicing good leads for damaged is another option, both sides are AC so it doesn't matter which wire goes to what, unless you are in the UK and the unit is earthed of course.
If the unit is intact and some of the lead is OK both sides, a terminal block connected close to the first break, nearest the transformer can eliminate the broken bit. If its damaged on the actual unit, unless you have someone that can get inside and rewire it (best option), you are looking for a replacement.
http://kurzweil.com/content/migration/downloads/pub/Kurzweil/Pro_Products/Other_Pro_Products/PC88/PC88_MusiciansGuide.zip
Apr 23, 2014 | Kurzweil Music Systems Kurzweil PC88MX
Flashing AC Adaptor
Is the battery any good? A bad battery will cause erratic operation of adapter/charger.
Jun 10, 2017 | Samsung Kitchen Ranges
My psp's ac adaptor port is broken. how, or who can it be fixed?
You have at least 2 solutions
1- Call Sony and tell them the issue you are having. You'll have to pay to get it fixed (depending on how much you'll have to pay you might be better off buying a new PSP.
The # for Sony is: 1-800-345-SONY Mon-Sat 6:00am-8:00pm PST SUN 7:00am-6:30pm PST
2- Do a search for a video game repair shop in or near the city you live in. Make sure it's an actual business at an establishment and not a random person asking you to meet at a parking lot.
Mar 01, 2011 | Sony PlayStation Portable (PSP) Console
Have a new computer with windows 7. my old husqvarna viking #1 sewing/embroidery machine software is downloaded, but unusable. Viking says to buy new software costing at minimum $500.00 The message I...
You will have to maintain an XP computer or buy new software there is no fix for your problem.It's the electronic age the old software was written for the XP operating system.When MS changed the operating system Husqvarna Viking had to design new software it's that simple.Don't blame the manufacturer Microsoft made the changes that created the problem. www.sewvac.com
Jan 28, 2011 | Husqvarna Viking 1
2000 Saturn LW1 ac doesn't work
A/C system needs to be recharged or repaired. Look in the yellow pages under auto repair and find shops with "radiator" in their ads, call them and ask them if they service air conditioning. If the system is shot, they can tell you before you pay for a worthless recharge. The car is 10 years old and many components in that system can be beyond their service life.
Jun 20, 2010 | 2000 Saturn Ls 4dr Sedan
Where i find ac dc adaptor durabrand portable pdv 705
You should go to a local electronics shop with the old adaptor.
They merely need to match: Voltage in Voltage out Current requirements Plug size Plug polarity (center positive or negative) There is nothing "magic" about the original vendors power adapter.
Oct 06, 2009 | Durabrand PDV-705 Portable DVD Player
Base no longer working. Unit is plugged in.
go to your neighbour"s house and check it there.
Jul 21, 2009 | Lands Phones
AC ADAPTOR 090-02180-I3
Here's the only place I know that sells them:
http://stores.ebay.com/LCDPAYLESS_LCD-monitor-Power-Supply_W0QQcolZ2QQdirZQ2d1QQfsubZ2195941QQftidZ2QQtZkm
It seem to be the #1 common problem with the Protron TV.
It maybe cheaper to find someone to fix the power supply, but if you get it from LCDPAYLESS, make sure it has some type of warranty on it. I hate to see anyone pay $130 and it only last a couple of months.
May 01, 2009 | Protron PLTV-32 Television
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
Faulty AC adapter
Same called Sears Placed and order Paid 136.95 plus shipping Tax total $168. 12 weeks no part with no due date
Apr 21, 2007 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
180 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
