Question about Canon PowerShot A75 Digital Camera
LCD Doesnt Display anything
Hello, when I turn on my Camera, it doesnt display anything and when I click a picture it is blank. How I know its blank, is when I download it to my PC. There is no cracks anything... Not sure what is going wrong. I have Powershot A 75 Regards, GK
  • gary1980 Aug 21, 2007
    This issue is confirmed when I took it to the Cannon Care.
  • 31 Answers
This might be a CCD image sensor problem if in shoot mode it displays only black screen, Canon will repair it for free, follow this link: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=9828&keycode=2112&id=29819
Posted on Aug 20, 2007
6ya staff
SOURCE:
Hi, When the camera is turned on, the LCD diaplay screen is blank (dark) and just displays various information icons for batterly level, megapixels, quality, flash-on, etc. When I try to take pictures, the...
The display being blank can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.since you are able to seen the ICONS the LCD is good , Now if the picture taken are seen well the CCD is also OK and the fault seems to be a digital logic gate failure as there is no switching of the circuit .
This might require a probe and it might be a relative issue in the motherboard circuit or the processsor. Remove battery , press down all buttons to drain off voltage and see if the camera resets.
Thank You for using fixya
Sep 27, 2011 | Vivitar ViviCam 4345 Digital Camera
My phone went coimpletly blank can i reset it
Dear,
u mean that phone doesnt show anything even the startup display and went completely black... so it can be the cause of strip that joints the LCD to the circuitry because in most cases of filp phone it happens alot... get it repaired....if the display doesnt see at all, the format or reset will not work...its an other case dear
regards,
hope it will fix the issue so dont forget to rate it..
Jul 06, 2009 | LG Vu CU920 Cellular Phone
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Blank LCD screen
problem is with lcd only may be its gone...
because in most cases they lights but doesnt show anything..
chirag
Apr 03, 2008 | Lexmark 4600 MFP
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
Canon powershot a540 black/web screen display
jvsnype and ygjeff21, have you checked to see if the pistures also come up as blank or distorted (a sure sign of a CCD failure)? If the pictures are OK, then it might be that you accidentally hit the DISP button, or the camera has a loose LCD ribbon cable connector. The reason I would suspect either is that ygjeff mentioned that the LCD would spring to life when he played with the buttons on the back of the camera.
If and only if the camera still takes good pics, and the DISP button has been checked, then would next recommend reseating the LCD ribbon cable into its connector (ALSO ONLY IF THE CAMERA IS NO LONGER UNDER WARRANTY). The following link may be of some help. Wouldn't recommend going any farther than the first three pictures. You just want to jiggle or reseat the ribbon cable where the LCD connects to the circuit board, nothing else:
http://photography-on-the.net/forum/showthread.php?t=251630
Feb 06, 2008 | Canon PowerShot A450 Digital Camera
Need help my samsung s630
my lcd isnt broken ive taken hundrerds of pics but all of the sudden it doesnt display anything just black screen like its off!! WTF!! i didnt do anything it was fine then 5 minutes later it wasnt
Nov 14, 2007 | Samsung Digimax S630 Digital Camera
Screen dosent display
if your laptop still turns on but doesnt display. change out the fl inverter. if that doesnt fix it then its your lcd screen. but i suggest first changing the inverter.
Nov 01, 2007 | Toshiba Satellite P25-S607 Notebook
LCD screen.. is blank and doesnt display anything thing
you have reach a sony service center for this there is a flaxi part which is not working and sony service center charges rs.2010/- for this
Sep 24, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Canon PowerShot A75 Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
