Question about Brother CS-8072 Computerized Sewing Machine
Will not sew
My machine was doing lovely for a whole week then yesterday while I was sewing along the tread bunched up on the underside around the bobbin. Now the bobbin thread will not catch at all. I have tried everything, I took it apart - cleaned it - made sure everything was in the correct position - tried every kind of bobbin and or needle I had - and still no success. It is only a week old and I cannot finish my dress:( Please if you have any insight, share.
  • Anonymous Nov 04, 2007
    THREAD NEEDLE
Had same problem with another Machine...I also have a cs 8072. it jumped time. any sewing machine shop can fix it in unser an hour for around $20-$30. Good Luck!!
Posted on Aug 30, 2007
There is thread pieces under the tread plate and when the machine tries to trim the thread it doesn't and sounds like it's hitting something
Sewing Machine Thread Bunching Up? Here's Why! - Craftsy
www.craftsy.com > Blog Home > Sewing Blog
Jan 21, 2014 - There are lots of reasons for sewing machine thread bunching up, and ... or bird nesting, on the top of your fabric, the culprit has something to do ... Frequent dusting underneath the throat plate and along the thread .... It looks like it's hardly been used but the top thread keeps tangling below the material.
Sewing Machine Needle Not Catching Thread ' ThriftyFun
www.thriftyfun.com/tf80302359.tip.html
Dec 20, 2015 | Sewing Machines
Skips stitches
I had/have the same problem...the gal at Joann's told me that it is USUALLY related to the needle being wrong for the fabric, an old needle, pulling as you sew, etc. Tweak everything possible, use a scrap fabric, keep resewing til machine behaves and then go to your real fabric. I always sew now with a scrap I test before doing something on the real piece. Also I was having bunching with my UNDERSIDE and assumed it was the bobbin thread. She told me the underside problems are from the top thread, not the bobbin thread..so she showed me how I was slightly threading wrong. I have a Singer Curvy and love it, but it is finicky when default settings are changed with stitch, width, length not matching the recommended settings. Good luck!
Oct 06, 2014 | Singer 3270 Mechanical Sewing Machine
My machine is stitching, it just keeps bunching on the underside of my material and I end up with this wad of thread. Why is it doing this?
check to see if the needle is damaged
some sewing machines bunch up on the underside when the thread come off the thread take up lever
Sep 27, 2010 | Singer 3116 Simple
The tread gets all bunched up on the underside of
Take the thread off the top of your machine and rethread it. Anytime a sewing machine bunches up the thread on the bottom the cause is the top thread. Make sure the tension dial is on "5". After you thread the machine, put the pressure foot down,(like its resting on fabric, but not on the thread), and pull the thread towards the back of the machine. It should be somewhat tight. The needle should "bow" slightly before the thread comes through the needle.
Oct 06, 2009 | Sewing Machines
Tread keeps coming out of the needle.
Make sure you sink the needle into the fabric before starting to sew. If that isn't it...remove the thread and rethread the machine. Make sure the thread isn't wrapped around the spool holder.
Apr 06, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread bunching
Check between the tension disc, sometimes you can get a piece of thread caught in that and it prevents it from tightening down and making a good stitch. Also, make sure that your presser foot is in the up position when you thread your machine.
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
I have a White 3300 embroidery machine not catching bobbin thread
Try putting a new sewing machine needle in and make sure the eye of the needle is facing the right way. Needles look like they should go just anyway, but if they aren't in right, it could cause the problem you are having.
Jan 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Remove your needle plate, and take out the black bobincase. Check the edges on the black bobbincase for scratches or damages. The upper tread should glide smootly around the upper edge of this bobbincase.
If you find any scratches, you may use a very fine sandpaper/grindingpaper (not shure what you call this in english) to remove the scratches.
Feb 20, 2008 | Janome Memory Craft 4000 Sewing Machine
Brother CS-8072 Computerized Sewing Machine Logo
110 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
