Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Sound my sound icon has dissapeared and now ive no sound at all. my speaker are workin fine and cant solve the problem
  • 883 Answers
First try using windows system restore, which makes windows appear like it did before your problem. do this sequence: start-all programs-accessories-system tools-system restore. run it and look for a calendar date before your problem. If you had system restore turned off, the solution may be long and painful and I simply do not have enough info to get you started in this case, other than to attempt a re-installation of windows XP.
Posted on Aug 18, 2007
  • Marty marty Sep 03, 2007
    do you still need help with this?
SOURCE:
I cannot get sound on yahoo messenger pool game ive tried everything i reinstalled messenger 10 i cleared my cookies ive got the latest java and ive even tried to change profiles Ive checked my volume...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Computers & Internet
Sir/madam, my laptop speaker is not workining properly. i installed sounds driver instead of this speaker is not workining . what can i do for solve this problem. plz suggest me...
try to reinstall the driver from your driver disk which provided when purchased
or download the latest driver corresponding to your model
Dec 13, 2010 | Acer Aspire One PC Notebook
Dimension 4700 my headphones work fine but i cant
Are you have the headphones and speakers both pluged in? When you plug in headphones the speakers get muted. You need to change your sound settings back to your sound card if you use usb headphones. The plug on the front of the 4700 also automatically mutes the speakers.
Dec 13, 2009 | Dell Dimension 4700 PC Desktop
My built in speakers or headphones r not workin
go to this website http://support.gateway.com/support/drivers/dlcenter.asp?cmpid=topnav
enter the model of your computer in the search engine on the right side of the page. locate the driver for sound for your computer and operating system and reinstall it.
incidentally look at the icon in the lower right of your screen that looks like a speaker... is there a red line thru it ?
robert
Sep 04, 2009 | Gateway M305CRV Notebook
Ive got a hp compaq lappy nly 6 months old.but the
check whether your audio driver is properly installed or not...to check that right click my computer and then 'properties'...and then select hardware tab and choose device manager...in that check 'sound,audio and game controllers' carrying any marks..if it is its a software problem..it can be solved by installing a proper driver to it...if these are not means its a hardware problem....first check the above steps and come to a conclusion.....
is this cleared your problem?
Jul 15, 2009 | HP Compaq Computer Speakers
I can not change the sounf volume
Start-settings-control panel-sound.
Jul 09, 2009 | Compaq Armada E500 Notebook
Cant make the center and 2 front speakers work
hello only you can do it if the total load may accepted by each channel....first take a look behind it read the total ohms by each channel now measure your ohms speaker make counts if they sum under or close to the load of your device thats fine connect them.if not dont do it or you may blow up your amplifier................saludos
Nov 22, 2008 | Pioneer VSX-D508
Speakers
Good day!
Did your computer installed the audio driver? Usually you know if you have installed the audio driver once you see a speaker icon at the bottom of your monitor or at the task bar. If not installed it first. If there is maybe the speaker was not activated, so you have to double click that icon, at dialog box will appear, click option then properties, activate the speaker.
Hope that solved your problem.
Thanks.
Oct 30, 2008 | Dell A215 Computer Speakers
Sounds
Good day!
Please check the cord of the speaker if it is inserted at the right socket of your unit, or was the audio driver was installed? check if you see a speaker icon at the task bar. If you see an icon (speaker) maybe the speaker was not activated, double click that speaker icon, then, see if the volume was check, or other options, if none click options, properties, try other options by checking the box.
Thanks hope can solve your problem.
Oct 28, 2008 | Dell A215 Computer Speakers
Scanner not workin-lexmark x1240
Which operating are you using if your using (Vista use windows photo gallery to scan)
Mar 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
