Question about Fujitsu Plasmavision P42HHA10 42 in. Television
Connecting an HDMI cable to Fujitsu Plasma P42VHA10W Display.
The Fujitsu P42VHA10W display does not seem to have a HDMI input connection for connection of modern DVD HD players/recorders via HDMI cable. It may have a DVI input or similar but I'm having trouble finding out and don't have access to a manual. If so,does this mean I need a DVI to HDMI conversion cable? or what?
Any relevent advice will be appreciated please.
Brian
  • AJax99 Mar 25, 2009
    I need to connect a Sky box to a Fujitsu Plasma P42HHA30AS, but it doesn't have an HDMI input.
SOURCE:
SOURCE: Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
most of the time, when the power light stay green, thr filter capacitors in the power supply have lost value, & need replacing.
When the power light turns red it indicates loss of signal. This could be the same problem except the input signal has been lost. Try replacing power supp;y caps , about 4 of them.
Works 90% of the time. Hobby of mine, Art
Posted on Dec 29, 2007
oakwoodman
  • 36 Answers
SOURCE: Apple TV and Sony KE32TS2 Plasma TV
That's weird... I just looked at the back of my set Sony KE-32TS2U and it has a DVI port.
Posted on Sep 16, 2008
SOURCE: Conrac Plasma Display 4042
Found cold soldering point on tuner board.
Posted on Nov 02, 2008
  • 23 Answers
SOURCE: HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Posted on Feb 17, 2009
tomlanik
  • 17 Answers
SOURCE: Confused on tv hook to Dish Network Box up Fujitsu Model#pds6101w
Call Dish Network for connection support
Posted on Sep 10, 2009
The TV inputs screen will not recognize a Toshiba VCR I've connected to it with red,white & yellow cables.
Because many VCR were not designed to work with these types of TV and the TV has no SCART socket you might have to convert it to fit.
You can do this using a box on sale at Amazon.
http://www.amazon.co.uk/SCART-HDMI-converter-convert-connect/dp/B0092IAA3I
Mar 16, 2016 | Panasonic TC-P42C2 Plasma TV, 41.6 -...
How do I connect the wireing
The VCR portion is connected to yhe TV via yellow-end cable(video) from "video out" to TVs "video in" and red and white-end cables(audio) from "audio out" to TVs "audio in". The DVD plays via HDMI cable from "HDMI out" to TVs HDMI in. S-video cable can be used if no HDMI terminal is available on TV. External tuner in (cable TV, Satellite) is connected to the video and audio in terminals or better yet if S-video out is available on the tuner box.
Aug 24, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
Jan 05, 2014 | Panasonic TH-50PX50U 50 in. Plasma HDTV
No audio input from TV on DVD Home Theatre
U have audio signal incompatibility. If the audio output is digital it may not work with an analog input, etc.
May 08, 2017 | Audio Players & Recorders
PICTURE SEEMS TO BE BLURRED WHEN ITEMS MOVE FAST ON SCREEN, ESPECIALLY PERSONS IN CLOSE UP.
The Sony Bravia KDL-32BX320 generally gets excellent reviews (4.5 stars out of 5) from owners, so I have to wonder what you're watching.
This is an HDTV and should excel when provided an HD signal to display. SD (standard definition) signals often look worse on an HD display than on an SD display. An HD signal is only available via the following ways (reference the image below):9_27_2011_4_28_11_pm.jpg
1) An "over the air" (UHF / VHF) antenna is connected to the cable / antenna input and there is a broadcaster of HD content nearby (only an over the air antenna can input HD signals to this jack - no cable boxes, etc.).
2) An HD Cable TV, DirecTV or Dish Satellite set top converter, Blu Ray Disk Player (or other HD source is connected via HDMI or Component RGB jacks.
3) An HD video played back from a computer hard drive connected to the VGA jack (when the computer is equipped with a modern processor and video card).
You will NOT be able to view HD video if:
1) The source material is a SD (non-HD) source. An over the air antenna will not provide HD signals if the broadcaster does not have HD content to show or is not capable of broadcasting in HD. Digital is not necessarily HD.
2) The source material (other than over the air antenna) is connected via Antenna / Cable jack.
3) The source material is connected via Composite jacks.
The USB jack is generally not an input for motion pictures, but may display stills - depending on the TV's ability to play the format they are stored in (jpeg, gif, bmp etc.).
Hopefully, this will help you solve the problem you're having with the picture. Good luck!
Sep 27, 2011 | Sony Bravia KDL-32BX320
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I have a Sampo 42 inch plasma multimedia display monitor model PME-42S6 (s). I got a blu-ray player and connected it via the AV1 inout. The screen is now green and red. What can I do to fix this?
If you have a Blu-Ray player you should be connecting it via HDMI, which is the only way to receive a full HDMI picture on your television. But you may connect it via the component inputs if you do not have an HDMI cord. The component cable consists of five color coded cords of (1) red and (1) white cable for the audio, and (1) blue, (1) green, and (1) red cable for the picture. Connect the Blu-Ray using this cable and you will be fine.
Feb 15, 2011 | Televison & Video
I want to connect my Fujitsu Lifebook N Series laptop to my HDTV using a VGA cable, but cannot get it to work. I have windows xp on my computer. I have tried using the display properties, settings but it...
One HDTV is New Technology. XP is OLD Technology.
Like putting a square rod into a round hole. HDTV's generally have HDMI ports that communicate with other HDMI electronics. You are required to have an HDMI Cable for connecting these devices. Computer in the 2018 era have HDMI ports. OLD XP Computers do not.
Jan 31, 2018 | Fujitsu LifeBook N6010 Notebook
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Fujitsu Plasmavision P42HHA10 42 in. Television Logo
1,085 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
