Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Ixus75 battery cover out
Hi my canon batery caver came out by mistake and now iam unbale to switch on the camera neither abl to put it back
    Champion:
  • 217 Answers
It's broken already.. Try to use magic tape or what they call it a quick release tape band.
Posted on Aug 31, 2007
SOURCE:
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
PROBLEM WITH - Cannon PowerShot A85:- The
switch off the camera and take out the baterys for a muinnuit then put nthem back in then switch on the camera if you still have the same problem you may need to use the same type of batterys as wos with the camera
Mar 07, 2011 | Canon PowerShot A520 Digital Camera
Any internal backup memory??
The internal memory only works when no card is in the camera and then only holds a small number of pics. If you had the memory card in the camera most of the time, most of your pics were on the card.
Jul 07, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
Formatting on Canon IXUS75
Formatting erases all information on the memory card, preparing it for further use.
If you haven't done anything else to the card since formatting, you may be able to recover at least some of the photos. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the card into a card reader attached to your computer and run the program.
May 14, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera option is showing "camera on standby". How to solve this p
you must service your phone because camera is gone , and better first you do this try to change your phone battery, maybe the batery is very consumed and old and can not react with camera on.
Apr 05, 2009 | Nokia 3110 Cellular Phone
P168+ Removing the battery
First remove the stylus. Then hold the top of the phone (where the camera lens is located, with one hand and the silver bottom of the phone with the other hand. Pull the silver case down about a half inch and then put your fingernail in the opened portion of the phone and pull back to remove the back cover. The battery is right there. Use you fingernail to remove it. Make sure you put the batery back in the same matter as polarity counts.
Oct 28, 2008 | Computers & Internet
Not taking pictures, screen is black
I had the same thing happen and by searching around for a solution today I came across is easy fix - give the camera a little "whack". It worked like a charm for me and several other people with the same issue. The issue was on this site but I can't find the exact one to link it. I hope it works for the rest of you - other people have paid the $100 to get it fixed, try this first!
If that doesn't work contact canon and see if they will honor your problem according to this advisory: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=10468&keycode=2112&id=48264
Apr 13, 2008 | Canon PowerShot SD1000 Digital Camera
Ixus 75
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 07, 2008 | Canon IXUS V2 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
