Question about Brother HL-2040 Laser Printer
Brother HL-2070N Replaced the toner cartidge, and the toner light stays on and will not print. Can you help>
  • Anonymous Oct 22, 2008
    29 of 29 people found the following review helpful:
    Masking Tape Gives TN-350 Toner a Second Life, August 25, 2008
    By
    C. MACPHAIL "cmacphail3"
    I get 800 to 1100 extra copies from each cartridge.
    After the "Toner Life End" message appears, it refuses to print
    even one more copy. Offensive...until you show it who's in charge.
    Remove the cartridge and find 2 clear plastic port holes, one on
    each side. The printer shines a light through these to decide when to
    shut you off. But it's too sudden and too early.
    Cover one or both windows with a small piece of masking tape. I get about 3400 copies per cartridge instead of 2400.
    (Report
    this
Brother HL-2070N - stars-5-0._v47081849_.gif Masking Tape Gives TN-350 Toner a Second Life, August 25, 2008 By C. MACPHAIL "cmacphail3"
After the "Toner Life End" message appears, it refuses to printeven one more copy. Offensive...until you show it who's in charge.
Remove the cartridge and find 2 clear plastic port holes, one oneach side. The printer shines a light through these to decide when toshut you off. But it's too sudden and too early.
(Reportthis)
Posted on Oct 22, 2008
  • 661 Answers
Did you remember to remove the seal on the toner cart? this is a breakaway tab usually on the side, this when pulled removes the plastic seal,(from inside the cartridge)
Posted on Aug 17, 2007
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Brother printer HL-2070N Stopped printing. Toner light stays on. Installed replacment toner cartridge. Rocked side to side to spread toner evenly. Cleaned the primary corona wire. Light still on. Will not...
go to the start of your computer and find the control panel and when you see the ad and remove program click it and and you see the currently install files find words brother printer HL. click it and remove after that please restart your computer din insert your brother printer installer cd into cdrm and install again maybe your current printer driver some files is missing, or reformat your pc using os/operating system and install the printer again make sure your printer have a load tuner or ink. thank you
Jul 03, 2009 | Office Equipment & Supplies
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Printing blank pages
This sounds like a laser or high voltage problem. Very much technical to fix.
Nov 01, 2008 | Brother HL-2070N Laser Printer
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL 2070n
Check the website of brother. If they allow you to download and update its firmware. Update the firmware and driver as well.
Mar 24, 2008 | Brother HL-2070N Laser Printer
Toner light still on after replacing with a new one
Drum counter usually has to be reset.. Check user manual or go to Brother's site if you want to drive yourself crazy Ed
May 04, 2007 | Brother HL-2070N Laser Printer
Brother HL-2040 Laser Printer Logo
534 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
