Question about Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw
Samsung shr 1040 4 channel dvr
I purchased this unit from Sam's Club. Hooked it up to a pc monitor and cannot access monitor. Any suggestions?
  • Anonymous Nov 27, 2007
    I hooked it up to a pc and canĀ“t have any image, how can I have access.
    I hooked cable to the VGA in the monitor, and the other end, to the lap top, what I am wrong?
    Hoping to hear from you asap.
  • dincerso Dec 24, 2008
    yes it is a good system but
    how to print out the pictures or the video? or how to take the video out of that?
    I need to give one of the copy to the police and I don't know how to?
I hook my shr-1040k and get no pickure Larry
Posted on Jun 12, 2009
Try this it will work:
Press and hold "ch1 and mode" buttons at the same time and hold for about 45 sec. This will change yoursetting to VGA . You can fined this info in your user manual on page # 6-13 see note at bottom of page for "HIDDEN KEY" shortcut's
It's a good system dont give up.
Posted on May 22, 2008
  • Lee Tanksley
    Lee Tanksley Oct 27, 2012
    tried this and still no screen
I think I can offer a solution. The unit is set up from the factory with television input enabled. You'll need VGA input enabled. Hook it up to a TV; go to setup in the menu and enable VGA. Then you'll be able to use your monitor.
Posted on Aug 24, 2007
2 Suggested Answers
SOURCE:
SOURCE: samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Posted on Jul 02, 2009
Samsung SHR-1040 Won't Initialize
try to reset the unit and start over.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Jun 12, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Apr 05, 2009 | Samsung Home Security
SAMSUNG DVR SHR 1040
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
Apr 05, 2009 | Samsung 4 Channel Dvr
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Samsung shr-1040
it comes with a built in code it is 4321
Nov 20, 2007 | Samsung 4 Channel Dvr
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Logo
1,655 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
Daniel
Daniel
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
