Question about Ricoh Aficio 1515F Plain Paper Laser Fax
Mode incorrectly switching to Handset
We have the 1515F Fax. We do not have a handset attached. However, the mode (all by itself) will switch to Handset. This interferes with our ability to send and receive faxes. The only way to fix the problem is to UNPLUG the fax and wait - 30 minutes seems to do the trick. Then the Handset mode will go away and we can send and receive faxes again. Until it happens again - which is frequently. We send and receive many faxes everyday and can't continue with this issue. Help! Thank you, Sue
  • Odaat Aug 19, 2007
    Thank you Brad! I am going to forward this to our tech guy who might be able to do something with what looks like great information!
    Thank you again,
    Odaat
Hi Sue, Can you tell me if there is anything else conencted to your fax line? Most Ricoh products will display handset if the dialtone is not detected. It could be that something is using the line or is causing it to short. Another thing to check if the machine is an older 1515- if this occurs after you receive a fax and you are behind a PBX, there was a batch of modems in the Ricoh machines that had a problem with not disconnecting the line, resulting in the handset being displayed. Could be any number of items, normally I would start the troubleshhoting with line issues and go from there.. Brad
Posted on Aug 19, 2007
SOURCE:
I CANNOT RECEIVE FAXES ON MY FAX MACHINE
Assuming you CAN SEND.???
Check to make sure fax is set to Fax mode and not Tel mode.
If you have a handset lift handset and make sure you have dial tone.
Try calling your own fax machine and see if it answers.
May 19, 2010 | Office Equipment & Supplies
Tel/Fax/Answering machine keeps freezing
Dear mariss34
While receiving a fax you shouldnt pick up the handset, but if u pick accidently then u will not recieve fax and hence u will hear an engage tone. If you are using a single line for both tel and fax then the party who is sending the fax should pre-inform you that it is a fax call so that when it rings you dont pivk up the handset.
You can also check your line weather it is working properly by using a normal telephone. This should be the first step rather, make calls to confirm it.
The last option is Power off the tel/fax machine for 3min completely and then try again.Also make sure the tel/fax is in tel mode and not in fax mode. Try to assign it in both modes.
If still you are not clear then the mannual which comes along with should help you, If still you cannot figure it out, Then you can call your service provider for help, they should definetely help you out.
Thankyou
Feb 10, 2008 | Office Equipment & Supplies
Error message -using handset (no handset on the machine. mfd - 1515
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Nov 17, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon Fax Phone
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 12, 2008 | Canon FAX-JX200
Just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3...
1. Press [Menu].
9. Press [Stop].
Aug 11, 2008 | Office Equipment & Supplies
Not sure how to setup the tel/fax mode correctly
1. Press [Menu].
9. Press [Stop].
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 31, 2008 | Canon FAX-JX200
My fax reads line in use
Make sure the handset switch is working.
Jul 29, 2008 | Office Equipment & Supplies
L170 Canon Fax Sound and volume control issues
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Help on KX-FLB756
the possible problem is found at analog board.. try to clean the handset cradle switch(the switch triggering when the handset is put down on unit)
Jan 18, 2008 | Panasonic KX-FLB756 Plain Paper Laser Fax
Ricoh Aficio 1515F Plain Paper Laser Fax Logo
360 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
