Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana SCD22JL Replacing the Defrost Thermostat fixed the fan problem. However I am getting very little air flow into the refrigerator side. The Defrost is working, the evaporator fan is running, the evaporator coils are not iced up, and the damper that controls the air flow on the refrigerator side is fully open. Any Thoughts?
  • Big TD Aug 17, 2007
    The coils are getting cold. as a matter of fact the freezer side gets plenty cold. It could be a matter of adjusting the thermostat colder to compensate on the refrigerator side.
  • Anonymous Mar 31, 2014
    Where is the damper control located and what does it look like?
    Novelist:
  • 87 Answers
It sounds as though you have a refigeration problem if there is no cold on the coil, however you hav sad that you have changed the sensor which would bring in the fan when cold enough. As far as airflow I have been doing this a while on American cabinets and never really consider airflow as a primary failure. If the fan is running and the vents are clear that is normally enough, these fans are not high powered and the cabinets have a large volume. What you could try is leaving the door open whilst observing the coil and see if it frosts right through the coil without the fan running. If it does then it should pull down to temp. Hope this helps, unfortunately without seeing things its hard to give a definitive answer.
Posted on Aug 17, 2007
Axd520sw IT ices up and the fan stops working therefor no cooling system in the fridge working. Also food in the freezer gradual defrosting. I can hear the compressor working though.
On the Amana refrig. when the Defrost thermostat goes out it will cause the 2 things your experiencing,when out it will allow frost to build up in the freezer& also at the same time the freezer fan will quit working,when the freezer fan quits working it will stop air flow into the rfesh food section. By replacing the defrost thermostat that should fix both issues at once.
This is what the defrost thermostat looks likeoldtech2332_36.jpgOn the Amana it will appear to be very similar to this one pictures the major difference,on it the wires will be BROWN &ORANGE instead of the orange/pink one shown here. It will be clipped onto the coil in the freezer coil behind the plate of the freezer wall. The OEM part# is R0160088 when first installing it,it will seem as if it wont work to fix it,the thermostat must get cold and once installing,it will take up to a 1/2 hour to get cold then you will hear the freezer fan come on.
The part can be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
midwestapplianceparts.com
apwagner.com
Aug 21, 2011 | Amana Refrigerators
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer in defrost mode
1 the defrost timer should cut off every 6 8 or 12 hours (unless its electronic or wired to accuminilate time). If the defrost timer is direct and alwaqys has the timer motor advancing every 6,8 or 12 hours it has to cut off. 2 I have had what I believed to be a clear defrost problem because the evaporator coil is froze up. However I find after a reoccouriung problem like you discribe that (maybe in addition to the timer) the suction pressure is low and the compressor is running all the time. Thus the sysytem is low on charge. 3 The frost pattern will be the most tell tell sign of your problem. A slightly clear evaporator on a few passes could indicate the need to check the sealed system and charge.A mostly blocked evaporator with little space for the air to be drawn through indicates agaIN THE defrost is not working or the defrost thermostat is cuting out before the heat has time to complete the defrost. A fan inside that is running and a freezer getting cold but the refrig isnt is mostly a damper or air flow from fan problem.
Jun 17, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Compressor and fan work on cendenser, evaporater works, but the fan on the evaporater in the freezer rear cuts off after the initial run cycle. The coils then freeze. What are your suggestions replace...
Probably a bad defrost thermostat. The fan motor power runs through the defrost thermostat then to the fan motor.If the defrost thermostat is opening too soon, you get no fan and no defrost.
Yes you can replace this part yourself.
May 03, 2009 | Amana 25.9 cu. ft. Side-by-Side...
Amana side by side keeps freezing up.
there is a thermoistat that turns on the fan when the coil get cold enough so that it doies not send hot air into the freezer compartment after the defrost is done. that could be the problem
Mar 30, 2009 | GE GSS25LGM Side by Side Refrigerator
Amana sx25sw - side by side - fridge not cooling
might be as simple as bad defrost timer( 10530703 $50)and/ or defrost thermostat(R0161088 $35), replace em both for under a hundred bucks. the timer is found behind the kickplate lower right hand side and the derfost thermo is wired in behind the rear panel atop the evaporator, and yea your right its preventing flow cause you "self-defrost" isnot functioning.Great frig though Id fix it
Nov 04, 2008 | Whirlpool GS6NBEXR Side by Side...
Amana SBDE520N
its quite possible, that "the box with thermostat and small door fix on chanel for regulating cold air from freezer in fridge side", is not the problem, there can be a few diff problems, the fan in the freezer may n ot be blowing the air over, you may have a bad defrost thermostat, preventing proper defrost cycles and building up with ice preventing proper air flow. i would look into a little more before condemning the part your lookin at( damper control)
Oct 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Aug 14, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
201 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
