My Indesit W123 control switch turns a complte 360 degrees when set. I have changed the bushes on the motor,the machine filled with water,agitated for about three minuets then went back to doing the same again. Ideas?
Your module has blown and im afraid this fault is not worth fixing due to the price of the board you may b able 2 get a second hand 1 but make sure it is a good 1 with a small g/tee rough price £50 good luck the module is mounted at the back of the machine at the bottom on the left hand side 2 screws hold it in place
Posted on Aug 19, 2007
It is so common that the washing machine can make
terrible noise in many ways and is a common fault. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that machine is
vibrating when it is running then the motor /drum suspension has to be
inspected. Since these fittings are located on the underside of the machine it
is important that you look for the noise with a good inspection lamp. Manually
turn the motor and drum and listen for the noise, if so the motor bearings, the
drum agitator shaft and fittings must be checked. Also the suspensions which
include the shock absorbers and springs, the body clamps must be checked to be
in correct alignment and not changed in position. Tightening of the
mounting is also very important. Finally
in most cases a drop of OIL or smear of grease on the moving parts cane solve
most issues.
Check this link :
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 20, 2013 | Indesit Door Handle Kit for W123, W133,...
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Jun 07, 2011 | Indesit W 123 Front Load Washer
Jan 06, 2010 | Indesit W 123 Front Load Washer
Dec 09, 2008 | Indesit W 123 Front Load Washer
Oct 26, 2008 | Indesit Washing Machines
Apr 28, 2008 | Indesit W 123 Front Load Washer
Feb 09, 2008 | Indesit W 123 Front Load Washer
Aug 30, 2007 | Indesit W 123 Front Load Washer
189 people viewed this question
Seems I hadn't tightened the replacemnt bushes on to the motor tight enough. Seems to be working fine now. Thanks for your effort.
Regards David
