Question about Sony VAIO PCV-W510 (PCV-W510G-BDL1) PC Desktop
Blue Screen I did not remember when it started but during tv screen is not shown after for a while only sound.It looks like hang After I restart PC on Windows mode after a few minites blue screen.
  • NoRush Aug 17, 2007
    Thanks a lot
    for this tip.
    This is XP home edition version,
    maybe reinstall professianol
    edition helps to avoid this problem.
    On other hand system logs says unstable
    condition of Photo Media Server.
    I stopped this service temporary as well
    Problem Solver:
  • 51 Answers
Use the system restore disk that came with your computer to restore the operating system. This should solve the issue.
Posted on Aug 17, 2007
  • Anonymous Aug 17, 2007
    If you install professional on a premanufactured computer that came with home edition, you will have to download all device drivers manually. it may not be worth the effort. However, windows xp home edition is not known for its reliability.
SOURCE:
Screen is showing all black things red
It sounds like your screen might be going bad. Normally there is no setting you need to be doing to adjust colors on your screen. There are some settings when you click Start/Control Panel/Display to look at your display settings, but these normally just control the color around the windows. For example the normal or default color for the strip that is at the top of your internet browser is blue but you can change it. I would say that when you boot your machine if the colors are not what they should be normally during the boot process, then your screen is going bad. You might try Opening a Word Document then type words such as Black, Red, Green, Blue, Yellow, etc. on different lines in the document. Then highlight the word and change the font color to match the word. This might let you see if your colors are true colors or if the screen is bad.
Mar 16, 2012 | HP Compaq nc4200 Notebook
How can i install windows xp on hp compac dc 7900. blue screen error shown during installation
Restart the process again...insert the cd in to the cd rom..restart the computer then you will see a screen which says press ant key to boot from cd...press space bar..the installation will start from the point where it was left when you received the blue screen...
If the blue screen is coming again and again then contact any local tech there might be some hardware issue.
Also make sure while installatng the windows there is no extra peripheral attached with the computer like printer,webcam,mass storage device etc.
Aug 18, 2011 | HP Compaq DC7900 PC Desktop
Vista - Windows explorer hangs during start
Sounds like a corrupt start up. Install your Vista disc and boot from the cd. After it loads windows it will give you several choices of what to do, choose repair startup and let the disc do its magic. When it is finished it will give you other choices after that. Take the disc out and restart and see if that takes care of the problem. If it doesn't, load the disc again and maybe try a early restore point, say a week before the problem started or think back to what happened to make this problem occur in the first place and go back to that restore point. You can pick earlier restore points then what is initially shown to you, just take your time. When restore is done, make sure to remove the disc.
Sep 02, 2009 | Gateway GM5472 PC Desktop
Sound card Driver problem under Win XP
download new drivers from driver detective..
or click bharatgulati.blogspot.com.
i do hv 1 problem..
"iam getting yellow vertical lines at startup screen..the lines are moving.system hangs after few sec. & sometimes it works perfectly.cant even format the system as it hangs.help"
Jul 22, 2009 | Computers & Internet
8 screens + blue screen + hangs
i think u need to reinstall the graphics driver, hope it would help. if it doesnt then visit the below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 16, 2009 | HP Pavilion dv2500t Notebook
Blue screen and toolbar shown, no desktop items on Linux eeepc
when u power up the computer press F8 key then enter in safe mode.
Then go to start menu then run type in run "chkdsk /r"
then press "y"
then also check in add remove program that there are not 2 antivrius if u find 2 then remove 1.
Aslo remover temp files cookies , tempo internet files.
Scan with antivirus.
remove unneccessary files and program.
then restart computer then
it fix error on harddisk.
Let me know.
Jun 13, 2009 | Asus Eee 701Sd Notebook
Compac presario R3000 problem
That screen is normal but only shows on certain occasions. Just use your arrow keys to highlight "Start Windows Normally" and press enter and you will continue to the blue sign in screen. If the removal software asks you start Windows in "Safe Mode", then restart the computer and select "Safe Mode with Networking".
Most common method for receiving that screen and those options is pressing a specific key during start-up for additional start-up methods. Another reason which may be the reason for your case is that something went wrong during start-up. Just follow the instructions above and it will be fine. Usually the reason why you are asked to choose is shown at the top of the screen and it will tell what the problem is.
Aug 11, 2008 | Compaq Presario R3000 Notebook
Blue screen setup TV in MS Vista Ultimate
hety restart u r pc in safemode
(f8 for safemode) then go to run and give
restore then select restore u r pc to earier working time.
it's so good in vista.
for help call me +919441133420
ur's kishorechowdary.
May 03, 2008 | Microsoft Windows Vista Ultimate Edition
Open Questions:
See all Sony VAIO PCV-W510 (PCV-W510G-BDL1) PC Desktop Questions
Sony VAIO PCV-W510 (PCV-W510G-BDL1) PC Desktop Logo
78 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
