I am Mr John
I have just got one Konica 7022 from Uk but now in Nigeria, I tried to power it with many difficulties it was ready to copy then I pressed the copy button but it pick a paper and jamb it, I removed it and power it again it gave me a Code (please call Service F-26-1 call 0870-2425050.
please can someone help to tell me what this code means and how to resolve it so that I can go ahead to make use of this Konica 7022.
I will be very grateful if someone can send to me ([email protected]) a PDF copy of the service Manuel of any of the following Konica copier
7020
7022
7025
7030
7033
7035
7040
7045
7065
7075
7130
7145
7155
7165
DB-208
DB-209
DB-210
DB-409
DB-410
DB-608
DF-311
DF-312
DF-313
DF-314
DF-315
DF-318
FK-101
Force 75
FS-105
FS-106
FS-107
FS-108
FS-109
FS-110
FS-112
FS-210
ISW
LT-352
LT-401
LT-402
LT-412
KN-302
KN-302A
KN-303
KN-304
KN-306
IT-101
IP-011
IP-110
IP-302
IP-303
IP-402
IP-411
IP-421
IP-431
IP-511
IP-601
IP-601M
IP-602
thanks John ([email protected])
L detect error. Check drum and sensor that monitors drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I have konica 7022 over here problem err f 26-1 please inform me how ca solve .
best reguard
rana from lahore PAKISTAN
Hello please check that you have toner on the machine, clean the mecanism of adding toner removing it and complete disarm and clean it, install it . run the code auto add toner, then the l detection code and check the copier.
jesus contreras ortega
SOURCE: Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Your TCR sensor is dirty. Your need to take out your process unit( drum unit) and vavuum waste toner out of the hopper, and clean the TCR sensor. this will fix your problem. first remove the developer unit one screw, than the drum unit one screw. place the drum unit on the copier w/the drum facing up. remove charge wire asy, drum shaft, and bearing, than the drum, remove the cleaning blade asy. you'll see the excess toner, vacuum all out. clean the tcr sensor, locate in the middle lower part of unit, under the drum. this should fix your problem.. lots of work though... good luck
