Question about SanDisk Sansa E280 MP3 Player
When i connect to the computer, i can add songs, but the songs on it dont show up
Ive had my e280 for about 6 months now, and i have around 3 gigs of music on it. I have permetnly synced it to Windows Media Player, and it charges and i can add songs just fine. But i cant see what songs i have on it, so i cant delete songs i dont want on there, i cant rename them, i cant view them at al. i have tried going through "My Computer-Sansa e280-Music", but the music folder isn't there. Any ideas?
Try setting the folder to "show hidden files & folders" (My computer-tools- folder options-view) fatalis666
Posted on Sep 05, 2007
I don't know if you've inadvertently deleted the music folder, but that's what I did, when I deleted all the folders by mistake, thank heavens for in-store warrenty, they replaced it with another one. What I noticed on my replacement is synchronizing with media player doesn't work, it creates ghost folders and thinks music is there when it isn't, I don't understand it. Solution: open two windows for my music and sansa e280 music, then just drag and drop the folders; what I noticed is that in my music the folders are named by artist, and I prefer to see them by album, but when I view them in the player, I see the albums with the tracks in the right order.
Posted on Aug 17, 2007
SOURCE:
I got a problem with my mp3
Transfers onto the m240 can be done in 2 USB connection modes:
MTP mode: Media Transfer Protocol using software, e.g. Windows Media Player 10 or higher.
MSC mode: Mass Storage Class using Windows Explorer, looking in "My Computer" viewing the player as a removable disk.
Typically, songs put onto the player in MSC mode can not be viewed in MTP mode and the other way around.
Switching to MSC mode in the player's menu:
Look in the player under Settings Menus > USB > select MSC for using the "copy and paste" or "drag and drop" method for transfers in "My Computer".
When Auto Detect is selected, it depends on the configuration of the computer, what setup for priority has been installed.
Forcing the player into MSC mode:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Information for the USB connection mode and how to make hidden files in XP and Vista visible, on the support site:
http://kb.sandisk.com/app/answers/detail/a_id/447
Manual for the m200 series players (readable with Adobe Reader):
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Don't hesitate to add a comment.
Apr 15, 2010 | SanDisk Sansa m240 MP3 Player
Songs have disappeared but must still be on memory
See this tip posted here, copy the address in to a new tab or window.
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
Feb 27, 2010 | SanDisk Sansa Clip MP3 Player
I dont know how to take songs off of this m p 3 player
To remove and add songs on this player, you can simply connect it to a computer via USB cable and when its detected already you can now remove and add songs from it...
Jul 09, 2009 | RCA Pearl TH1102 MP3 Player
Song names in X20
i think you should try this...
if you dont already, download iriver plus 3
install it
open iriver plus 3
plug in iviver
go to tools>Portable Device>Disk Initialization
this should format your iriver and replace all the original files
i reccomend only putting music, video, pictures and ebooks on via iriver plus 3
and also please make sure you safely remove the iriver each time you connect it to the computer
if you dont, there is a chance that you will screw your iriver, you may have heard of the "building library" problem, which nobody has found a solution for yet.
i hope this helps you!!
good luck!
Jun 06, 2009 | iRiver X20 MP3 Player
How do a veiw my library on my mp3
Plug your mp3 into the computer using your usb cable. Open windows explorer and click on drive "E". it might be different on different computers but a little playig around should find it. Then by trolling through it you should find all the files available on your mp3. Your problem was created by removing it from the computer without using the safety hardware removal. I still have not found a simple method to rectify this problem.
Feb 25, 2009 | GPX MW3837 MP3 Player
Samdisk MP3
1. plug in Sansa to computer
2. Open My computer
3. Click on your Sansa
3. Click MUSIC
4. Delete the songs you dont want on it...if that folder is empty make sure you have windows showing all the hidden files... use windows media player and go to sync and put songs there..hope that help..
Jan 20, 2008 | SanDisk Sansa e260 MP3 Player
Cant load songs to my ilo player!!!!!!!!!!!!!!!
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Use Windows Media Player instead
Oct 20, 2007 | iLO (2 GB) MP3 Player
Can't copy songs on to SD 2 gig Card in Sansa e250
the card shows up as a separate drive letter, remember that
when the card is in the player, look for the second drive letter in My Computer and add the songs to it not the first; yes the card will show up in your library on the player only after you have unplugged it and restarted the player.
Oct 18, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
387 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
