When initially plugging in the unit, the panel will light up for a second and beep and then all the lights go off, and all the buttons are unresponsive. The green TEST light on the cord stays lit the entire time.
SOURCE: Frigidaire AC Window, Model # FAC107P1A2
you have clearly mentioned in your question itself that electrical cord does have power going into the unit.i feel it may be the problem with your power cord wire . try replacing the cord first and check whether the power reaches the unit.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
SOURCE: my frigidaire air conditioner cord
hello
I would have the cord replaced.The test and reset is a ground fault,or a saftey device.
If its not working correctly then have it replaced
SOURCE: my fridgedaire window unit A/C and heat won't
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
Testimonial: "Thank you. I had pretty much come to that conclusion. I think It may be a faulty outlet or circuit breaker, like you said. Thanks for the advice!"
SOURCE: frigidaire FAH12ER2T thru wall AC won't turn on
check for internal fuse or a start/run relay
