Question about KitchenAid KGSA906PSS Gas Kitchen Range
KGSA906PSS HELP I was self cleaning my oven this am and in the middle of cleaning it just shut down! I unplugged it and repluged it in and still nothing. The stove works but the oven is LOCKED shut and the panel is blank! Please help any all suggestions appreciated!
    Problem Solver:
  • 4 Answers
Took me almost three months to get a new range, and kitchenaid still insist it is an "isolated incident"... They need to be exposed and sued...
Posted on Jan 31, 2008
SOURCE:
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
I have a kitcheaid gas range. just used the quick, self-cleaning cycle/2 hrs. 30 mins./went out came back no display and door will not open/
The temperature cut-out thermostat at the back of the oven has failed. You will need to pull the oven out and remove the back panel. Thermostat should be at the top in the middle. Once replaced oven will be back to normal.
Feb 26, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Self cleaning attempt has shut down the control panel.
You need an air flow kit, part 81911788 and a professional to install it.
Dec 23, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchenaid KGSA906PSS gas slide in
GO TO THE WEBSITE TO GET THE PROPER
INSTRUCTIONS FOR YOUR UNIT AND WHAT
CLEANERS CAN BE USED FOR YOUR UNIT.
Mar 07, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Ran self clean on my oven and it stopped in middle of cleaning cycle
That most likely means there is a fault in the control board. You need to contact the manufacturer or retailer for service.
May 17, 2017 | Whirlpool GBS277PDS Electric Single Oven
Oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
Jul 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven door locked
Please check my earlier post on this problem.
I forgot to add that the only way the Tech is able to get the oven door unlocked after it shuts down in the Self-Clean (Self-Destruct?) mode is to take a pair of pliers and short across the bad Thermal Protection swtich before replacing it.
Mar 22, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Self Cleaning ShutDOWN HELP
i had the same problem... the thermal circuit in the back had blown,,little rond thing the size of a quarter with two black wires plugged into it. had trouble getting the door open though,,good luck
Aug 17, 2007 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
244 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
