Question about Dell DJ MP3 Player
Dell Digital Jukebox
My Jukebox appears to have crashed. It is in Rescue Mode. I have rebooted. I have tried to down load firm wire. When I reboot it, it goes back to rescue mode. When I try to redownload the Firmwire, it says "Harddisc Problem". What do I do. I don't want to lose all of my music.
    President:
  • 317 Answers
The solution to many random problems is to simply reset your Dell DJ. This can be done by using a small, thin object (such as the tip of an ink pen) to press the reset button that is on the bottom-left side of the DJ. -or- Hold down the play/pause button while it's off, insert a paperclip into the reset button, take it out, and then let go of the play/pause. The DJ should open to a rescue mode, then run disc clean-up.
Posted on Aug 17, 2007
SOURCE:
Anything unusual happen to the player before the problem started? Dropped it or perhaps unplugged it from pc while synchronising? The most likely fixable problem is a loose connector on the HDD/main board cable, or a failing battery/power adaptor giving the HDD a voltage too low. unfortunately however the HDD on these players is a bit vulnerable to rough treatment. When you connect it to a computer, does it still appear as normal or is it not recognised etc. What operating system PC are you using - perhaps formatting from the PC first before trying to install the firmware will help. Are you using the latest firmware from Dell or are you using a cd that came with the player? Is your player still under warranty or do you want to try and open it up and have a check yourself. Let me know more info and what you wish to try :)
Aug 17, 2007 | Dell DJ MP3 Player
Trying to recover nomad jukebox zen extra
Get an original Vista operating system disc..
then insert d CD and boot from the CD!
Apr 29, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Dell Jukebox is stuck in Rescue Mode
did any of this stuff actualy work?? because i am having the same problem with mine the only thing is as long as i've had mine i didn't even know where the reset button was.
Mar 23, 2009 | Dell DJ MP3 Player
Mad at my nomad
It appears that my Creative Nomad Jukebox is stuck in the Rescue mode. It displays the four options suchn as. 1.Clean up 2. Format all 3. REload OS 4. Reboot
It is not recognised on the computer either.
Steve
Dec 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Turns on then turns right back off after 2 seconds
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
if you can get into recovery mode most likely bad hard drive
Nov 05, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomand Jukebox Zen Xtra
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
My Zen worked and then stopped....
7. Problem solved.
then download current firmware from creative downloads
Oct 30, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Dell DJ MP3 Player Logo
262 people viewed this question
Top Dell Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Steve Mason
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
