Question about Mitsubishi WS-55511 55" Rear Projection Television
Auto Shut Off
Originally, video went out sound remained on. Cycled power, now TV shuts off automatically after a few seconds without audio/video ever comming on. Picture going out with audio on makes me think it is a HV problem and that now the power supply is in an autoprotect mode, shutting the tv down during a power ON selfcheck. Any feedback is appreciated.
  • EEPE Aug 18, 2007
    I already have the manual. Thanks. The diagnostic says error 22, Short. I tracked down 2 bad components. D9A60 & F9A04 both in the +24V supply. C9A68 is also questionable. This supply feeds IC8C01 (Convergence Amplifier) which appears to be the culprit. When I took board out of the set, I found fluid on the board and the leads on IC8C01 have separated from the die. What is the fluid? Only thing I can think of is the CRT coolant. Any other possibilities? If it is the coolant, is this something a skilled do-it-yourselfer (Professional Electrical Engineer) can tackle or are there special tools required?
  • Anonymous Mar 31, 2014
    My TV is not wokring at all, I can power on, in about 2-3 seconds it makes a sharp buzzing/Shocking sound and turns off. What could this be?
    President:
  • 3,130 Answers
It is a possibility, bu there is a self diagnostics on the TV set to help guide you to the problem. I do have this service manual that will assist you to service the problem you have. That's a bargain. This manual is normally 25 bucks! The self diagnostics in on page 30 of the service manual. Please leave an e-mail address if you wish to receive the manual. It will not fix your set, but can get you on the path to a repair. Good Luck
Posted on Aug 18, 2007
  • Larry  Dillon
    Larry Dillon Aug 18, 2007
    Yes great guess on the fluid. You will need to take the board out asap and wash the board off really well as this fluid will corrode the board really bad, and after a while the traces will burn off the board. The fluid leak if not a really bad one can be left alone as long as the fluid loss does not affect how the picture looks. You will have to wait for the set to work before you decide if the picture on the leaky tube is causing a color shadow in the picture. If that is the case, the tube will need to be removed from the set, the fluid drained, the lens assembly removed and you will need to obtain a new "O" ring to seal the fluid into the tube. You can get the coolant fluid from mcmelectronics.com Just go to the site and under search, type in coolant fluid. You can also get the right replacement IC's for the convergence there as well. Do not go for the least expensive, as most sites carry the cheap aftermarket IC's and they do not always have the same specs as what the manufacturer calls for. Now if the fluid is just a small leak, Hitachi and Mitsubishi uses a flat piece of plastic under the picture tubes to redirect the leaking fluid. Let me know if you need any further assistance.
6ya staff
SOURCE:
Yamaha sound bar YAS101BL periodically shuts off by itself
It has an auto sleep function. if no button is pressed after 12 hours it will automatically shut down. See http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/ats-1010/7727/6890
Mar 01, 2013 | Yamaha YAS101BL
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Sony Grand Wega KF50WE610 Video/Audio disappears every 1-2mins
Hello apharcha,
99.99% its the lamp. You may also have a faulty door, but thats kinda just 2% possibility. Change the lamp...its due anyway.
List Price $200.00
Part Number A-1606-034-B Description LAMP BLOCK XL2100U
Best regards
circuitcity
Jun 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv shuts off sporadically, and now won't recieve any video signal
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
May 07, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Westinghouse TV - Issues
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/..
Mar 10, 2017 | Westinghouse LTV-19W3 19 in. LCD...
During DVD movie playback, screen goes black periodically
it could be that the disc is and ordinary dvd disc and cannot stand the capability with a high def tv because i have the same problem and when 1 put a bluray disc in its fine
Mar 10, 2008 | Sony Playstation 3 (PS3) Console
Won't turn on
Hi, The camera has automatic in function , if you turn on camera without pressing the camera within few seconds it will shut off automatically, You just press shooter it will on instantly.
Jan 09, 2008 | Sony Cybershot S650 Digital Camera
Mitsubishi WS-55511 55" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
