Question about Interactive Media Kanguru Presenters Mouse (KMOUSE-PRES)
Logitech USB mouse Model # M-RAG97-does it have an internal battery, and if so, how do you open mouse?????????????
Turn mouse over - 2 screws under label - you can see the idents
Two other screws under rerar - remove feet or just punch though
the feet to get to screws.
Best of luck
Colin
Posted on Apr 11, 2009
  • 59 Answers
It does have an replaceable internal battery. There are 4 screws on the bottom of the mouse. Two are under the label and two are under the rear foot pads. Pry the bottom off of the mouse carefully. Disconnect the battery cable from the mainboard. Remove two screws from small plastic piece holding the battery in place. Replace battery. Reverse dis-assembly directions charge mouse and you are good to go!
Here is a you tube video for reference:
MX1000 Battery Replacement Video
Here is a site that sells the replacement NTA2253 battery:
NTA2253 MX1000 Battery
I hope this helps!
Posted on Dec 03, 2012
SOURCE:
Clicking issues on logitech wireless mouse
  • 1 Use the mouse on the same side of the computer where the Logitech USB transmitter is attached so there is a clear signal between the transmitter and the mouse.
  • 2 Check the USB transmitter that comes with the Logitech mouse to be sure it is correctly plugged into the computer. The red LED should be illuminated on the transmitter if it is connected properly. If not, the signal cannot reach the wireless mouse.
  • 3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
  • 4 Check the battery compartment by sliding the top housing off the mouse to confirm the rechargeable batteries are installed correctly.
  • 5 Charge the batteries if the mouse LED does not illuminate. The charger cord plugs into the front end of the mouse and the other end connects to a free USB port on the computer.
  • 6 Clean the desk surface or other flat area if the mouse is not tracking. The problem could be dirt or grease interfering with the tracking ability of the device.
  • 7 Open the Logitech software called SetPoint, which manages the mouse, to troubleshoot button functions. Open the program by double-clicking SetPoint from the list of software on the computer, then click "Mouse Settings." Click the "My Mouse" tab and check (or uncheck) all the task boxes that are desired for operating different mouse functions, then click "Apply" and "OK."
  • Mar 17, 2012 | Logitech Cordless Mouse
    How do I change the battery in a logitech wireless battery. I can't seem to figure out how to open it to even see what kind of battery is needed.
    For changing the batteries of logitech wireless.I guess a video tutorial will help you out rather than written instructions. Watch it to lean how to replace battery of the logitech cordless mouse ( Logitech MX 1000 Model). If you are having a different model please specify the details of your model.
    Mar 02, 2011 | Logitech Cordless Mouse
    How do I open wireless logitech mouse to change batterie. I do not want to break anything by forcing it open
    hold your hand on the bottom of the mouse on the battery door and then your other hand on top of the mouse and push that hand outwards while pulling back with your other hand.
    Mar 01, 2011 | Logitech Cordless Mouse
    How do I change the battery for my logitech cordless mouse? Can't find opening for battery....
    hi marlys, i am happy to assist , Ya its not too easy to replace battery in logitech cordless mouse,in the back of mouse, you have mouse pad just remove it , you can see they provision to remove the mouse, there been Four screws been inside that mouse pad, But before going to open your mouse just check you have new battery with you, if you connt find in any shops just go to eBay , you can get it thee, If you mansion the excate model name of your mouse mean i will send video for that particular model itself , no issue just check out this video
    Jan 06, 2011 | Logitech Cordless Mouse
    Mouse stopped working, how do I replace the battery? I do not see anywhere to open it up and replace one. Model? it works with my mac book, wireless the a usb plug in.
    Hi there as per my logitech mouse the battery removing place is just below the mouse. You can see a arroe sign near in the mouse sencer light. Just unlock & the battery will came out. Thanks & waiting for your feedback.
    Mar 17, 2010 | Logitech Wireless Access Duo Optical...
    How can i install my cordless mouse with no instalation cd
    Hello
    place batteries in mouse.
    connect The Transmitter/reciever to the pc ( probably USB) and then press the sync button under the sender if there is one, and then press the sync button under the mouse.
    windows should recognize it.
    To get the driver search for your model on the manufacturer's website
    and download the driver ....install driver and plug mouse in.
    If this does not work let me now what OS ( operating system ) you are running.
    and what you are plugging the mouse into.
    Feb 24, 2010 | Logitech Cordless Mouse
    Replacement USB charging cradle for Logitech Mouse
    It sounds like you are talking about a wireless unit, and I am going to assume that it has stopped charging.....Try this first before you purchase a new cradle for it....Take a pencil eraser and clean the terminal prongs on the cradle, just as if you were erasing on paper, then do the same to the terminal plates on the mouse....
    Sep 27, 2009 | Computers & Internet
    Where's the batteries?
    I had a similar problem with my battery going dead in my Logitech mouse. There was a "aa" battery located under the rear top cover. it's the part that has the Logitech logo on it. You simply press the button underneath the mouse @ the back that has a LOCK symbol on it & lift off the cover. Put in a new battery & you should be good to go.
    Fred
    Oct 01, 2007 | Logitech Cordless Mouse
    Interactive Media Kanguru Presenters Mouse (KMOUSE-PRES) Logo
    2,689 people viewed this question
    Top Interactive Media Computers & Internet Experts
    Alun Cox
    Are you an Interactive Media Computer and Internet Expert? Answer questions, earn points and help others
