Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Dishwasher not cleaning well
Tablet dispenser tray does not seem to be opening during a wash cycle as their is a soapy residue still in the dispensing tray after a wash and the dishes are not always clean
  • kaz61 Nov 19, 2007
    Have just bought this dishwasher second-hand.(not this model) is about 12 years old i think.. runs through the cycle fine(water heats)..but the powder dispenser hasn't opened at all..have cleaned around the edges...?
  • Anonymous Mar 20, 2008
    I've checked the latch to the tray (put WD40) on it and it opens easily now. I tried a wash and again the dishwasher tablet was still in it's place so the dishes were washed in water only. This has happened on the last 3 washes.
  • 641 Answers
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Good luck!
Posted on Aug 18, 2007
SOURCE:
Lg dishwasher soap dispenser does not open during wash cycle
It is usually due to a lid spring problem or the solenoid operating the lid is faulty. In any case you need to replace the whole dispenser assembly. It looks like this (item K001) in this assembly chart.
http://www.appliancepartspros.com/section-4-parts-for-lg-ldf8812st-asteeus.html
To save hassles it might be worth switching to the dishwasher tablets instead of the powder. You simply drop the tablet in cutlery basket. A good brand like Finish should do you wonders. Might seem a bit expensive per wash but you extend the life of the dishwasher due to its cleaning efficiency.
Apr 21, 2014 | LG LDF8812 Stainless Steel Built-in...
Detergent dispenser on SMEG DWF 44SS1 doesn't open during cycle - any ideas?
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Oct 18, 2009 | Smeg 24 in. DWI612 Built-in Dishwasher
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Dec 24, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Detergent Dispenser does not open
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
400 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
Paul Bade
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
