How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install,
speakers, dvd player, in dash, acura integra gsr del sol honda civic itr
ls b16 hatch coupe jdmkey
words: honda acura integra gsr itr jdm del sol coupe hatch ls si
boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG,
EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX,
engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1,
B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC,
V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C,
B18C1, B18C5, D16, D15, integra civic, b18, turbo
spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic
Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16
b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude
sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series
integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude
accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx
accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota
volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d
series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude
jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx
rims si rims gsr blades ls distributer distributor rota rotor aem injen
akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r
civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef
ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC,
B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5,
D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos,
turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs
subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
with the car running it's 14.6 at the battery and at the end of my power wire when its NOT hooked up to the amp. It goes down to 3.5 when its hooked up to any amp...and im not sure if this is a problem but with remote and ground hooked up 2.75 volts is coming out of the empty battery terminal...thanks for the help
i don't think it is the equipment and i don't think a cap will fix it..... if the car is running, what voltage is at the battary? and where is the 3.5 volts measured from? could be a key barrel problem?
