Question about GE 32GT660 32" TV
Turns on an off by its self
When trying to turn the television on it will automatically shut off and try to repower up on it on numerous times....eventually it may come on, but not always. Could there be a problem with the power switch? And is this something that I can fix or do I need to go to a repair shop?
    Problem Solver:
  • 18 Answers
In order to fix it yourself you will need a digital VOM meter (preferably one that can test diodes) a 25 watt soldering iron desoldering wick and a cap analyzer. Otherwise you should take it to a shop.
Posted on Aug 17, 2007
SOURCE:
Vizio tv comes on then turns off
Corrupted software. Try after a softare upgrade.
Gopakumar Gopalan Google
Apr 20, 2014 | Vizio L37 Television
It just turns its self off
have you tried accessing the self diagnosis feature as soon as it shuts down to see what the blink code is? If so let me know the error code and I will assist you with the issue
Dec 09, 2012 | Mitsubishi WS-65411 65" Rear Projection...
When I turn my TV on, it comes on and says 'no signal' then after about 5 seconds, automatically switches its self off... any idea why?
Most sets will shut down very fast if no signal at all.
If you can before it shuts off try to change input to one of the rear audio video inputs that has something connected to it and turned on.
Failing there and if using a box of some type for signal--unplug it and the set both for a while---plug back both and let each try to boot up.
A total loss of signal or a glitch with the set or a box can confuse the TV set's Microprocessor.
May 30, 2012 | AOC L32H961 32 in. TV
Vizio M470NV just purchased, while watching TV it turns off with the Vizio light blinking between orange and white. Can not turn back on !! I have to just wait for about a minute then tv turns back on by...
I have the same issue on my Vizio M470NV. I called Vizio and they told me it is a self diagnostic test that is shutting down the TV automatically to protect it. They said they are working on fixing the issue with a firmware update that will be pushed out automatically if you are connected to the internet. No ETA given on when that would happen. I called them on the 3/14/11 and my TV is still shutting down randomly.
Mar 18, 2011 | Televison & Video
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Ws65711,8 years old, working great with out problem until this one..turned off the tv normally after use, then when tried to turn on again... it turns on (green light turns on. no pictureno...
SD TECH,
Just started experiencing convergence problem with my Mits ws-65711. I have decided to try to repair on my own and have the service manual. I see also you have step by step instructions for the repair and perhaps photos of the fuses. I could really use this info if you are able to provide.Thanks in advance. I did the self check by holding in MENU and INPUT buttons and got 1 green blink followed by 2 shorter/quicker green blinks?
Aug 30, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Turns on and off automatically
getting hot and shutting down try to clean it out could be very dusty inside
Jun 21, 2009 | Gateway GTW-P42M303 42 in. Plasma...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Monitor not seeming to work when computer is powered up.
Hi there!
Try reseatting the video card and clean the video card if needed and the memory module.
Mar 07, 2009 | Computers & Internet
Lcd tv
I've brought a 32"bush lcd tv from Argos yesterday and the picture went off but the sound never
Tried turning it off but no change what is the problem
Aug 01, 2008 | Bush Televison & Video
Televison & Video Logo
23 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
